Head warpage how much is too much
Old Jun 1, 2005 | 12:04 PM
illcrx's Avatar
Default Head warpage how much is too much
I have a 90 crx hf that just blew a head gasket how much warpage on the head is too much, with a straight edge .013 mm is the warpage, I think its too much but just let me know.
Thanks
Randy
Old Jun 1, 2005 | 12:07 PM
CRseXy's Avatar
Default Re: Head warpage how much is too much (illcrx)
Ide STILL go get it milled down.
Old Jun 1, 2005 | 12:59 PM
Tyson's Avatar
helms says:
cylinder head:
.05mm-.20mm requires resurfacing
engine block:
.07mm is new. .10mm service limit.
id say you need to mill it....
Old Jun 1, 2005 | 01:04 PM
PURPLETERROR aka BIGMATT's Avatar
mill it
Old Jun 2, 2005 | 04:41 AM
StorminMatt's Avatar
Before you do anything, you should take out the rocker arms and install the cams with the cam bearings. Make sure that the cam is not binding due to the warpage. If it is, get a new or used head. You might want to get a new head anyway if you can find one cheap.
Old Jun 2, 2005 | 11:50 AM
boostedSI90hatch's Avatar
Banned
Default Re: Head warpage how much is too much (StorminMatt)
if you dont get it reserfised your are going to not have a good tight seal (head to block) so yes get it reserfised.
pinoy_93cb7
Jul 6, 2011 01:29 PM
bmg123
Feb 7, 2010 07:20 AM
cBrown05
Oct 9, 2009 07:48 AM
1BADEGDC2
Feb 17, 2008 09:56 AM
Tigfab
Jun 3, 2007 03:04 PM
