which rod to use between the two?
if i am building an all-motor 95 gsr block with type r pistons,and a gsr crank,would i use type r P73 rods,or gsr P72 rods? any help is appreciated,thanks.
Either will be fine, if you already have the gsr rods use them, matching the color codes with the bearings will be easier. Type r rods are slightly stronger bit really not worth it. Goodluck with your build.
i dont have either rods yet,im just trying to make a descent n/a daily driver,with a good amount of power,not too much or too expensive.i am most likely going to just order a set of rods right from honda.i got a set of oversized P73 pistons (oem honda) from JHPusa.com,very good seller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0honda »</TD></TR><TR><TD CLASS="quote">b4 you order rods from honda buy some aftermarket ones. would be close to same cost.</TD></TR></TABLE>
Yeah I agree. If you want some stock GSR rods I'll sell you mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsnm »</TD></TR><TR><TD CLASS="quote">are they new rods?</TD></TR></TABLE>
No they are used. Just buy some ARP rod bolts and you are good to go.
vtecjj
May 15, 2006 05:54 PM
