Holy 7 MegaPixel Sony Camera Batman!!!!! Great price on Brand New Sony P200!!!
LOOKING TO GET $350 shipped O.B.O.
Hey guys and gals I just bought this camera and really would prefer to put the money into my car rather than into this
The camera is brand spanking new all the manuals, cables, battery and charger etc. have not even been used yet. The only reason that I dont take it back to Best-Buy is because (like an idiot) I threw away the box
I will post up actual pics of the one I am selling soon.
Here are the specs from the Sony site:
• 1/1.8" 7.2 Megapixel Super HAD™ CCD
Super HAD (Hole Accumulation Diode) CCDs provide excellent image quality by allowing more light to pass to each pixel, increasing sensitivity and reducing noise.
• 3X Optical/2X Digital/6X Total Zoom
Optical zoom helps you fill the frame with your subject for better pictures. And Sony’s Precision Digital Zoom helps bring your subject closer with an extra 2X magnification
• 0 –14.0X Smart Zoom™ Feature (at VGA Resolution)
The Smart Zoom feature intelligently uses the full CCD to let you zoom into the portion of interest by cropping the image size–thus avoiding the image degradation of Digital Zooms.
• Carl Zeiss® Vario-Tessar® Lens
The Vario-Tessar lens is specially produced for very compact cameras. This specialized design allows quick auto-focus, appealing zoom range while still maintaining a compact design.
• Real Imaging Processor™ LSI
The innovative Real Imaging Processor™ LSI in the DSC-P200 not only improves picture quality and clarity but also improves camera response time, decreases shutter lag and improves battery stamina.
• Live Histogram Display
Available in capture and playback the Live Histogram displays the concentration of pixels at each luminosity value making it easy to evaluate correct exposure.
• 14-Bit DXP A/D Conversion
Sony’s 14-bit Digital EXtended Processor captures the range between highlight and shadow with up to 16,384 values, for extended dynamic contrast and detail.
• 2.0" LCD Monitor1
2.0" LCD provides a high resolution view while shooting. Unique in such a compact camera, this large screen makes it easy to share image playback with friends.
• 5 Area Multi-Point Auto Focus
By evaluating 5 separate focus areas of the frame, Sony’s Multi-Point AF system can intelligently focus on the subject and avoid mistakenly focusing on the background.
• Manual Exposure Mode
Manual Exposure Mode provides extended control with 46-step adjustable Shutter speed (30 – 1/1000 sec.), and 2-step Aperture control.
• AF (Auto Focus) Illuminator
Briefly illuminating the subject, in low – or no – light conditions, the AF Illuminator helps establish a positive focus lock.
• Selectable Focus Mode
Monitoring AF (Auto Focus) helps you anticipate the action by focusing even before you press the shutter release.
• Multi-Pattern Measuring
Independently light-metering 49 points of the frame, Multi-Pattern Measuring establishes the optimum exposure, even when highlight and shadow isn’t centered in the frame.
• Scene Selection Mode
With 9 Scene Modes, parameters can be matched to the shooting conditions. Choose from one of the following: Twilight, Twilight Portrait, Landscape, Soft Snap, Candle, Snow, Beach, Fireworks, or High Speed Shutter
• Pre-Flash Metering
With a momentary pre-flash, the camera illuminates the subject and sets exposure through the lens for accurate flash metering. Adjustable flash level and red-eye reduction ensure great flash shots.
• Memory Stick® Media and Memory Stick PRO™ Media2
Digital. Powerful. Transportable.™ Memory Stick® media is compact, portable and rugged – connecting a variety of hardware and software applications3.
• 5 Shot Burst Mode
Capture up to 5 shots (7MP fine) or up to 100 (VGA standard) at 1.1 frame/sec. even at 7 MP resolution. Perfect for high speed subjects or fast moving action such as sports
• Multi-Burst Mode
Captures 16 320 x 240 frames as part of a single 1280 x 960 image which plays back sequentially in the camera. Selectable 1/7.5, 1/15, 1/30 second.
• MPEG Movie VX Standard/Fine Mode with Audio
Captures VGA (640 x 480) high frame rate (up to 30 frames per second) audio/video clips with length limited only by the capacity of the media. Video mail mode captures smaller file sizes suitable for email.
• Conversion Lens Compatible
With VAD-PHC adaptor, you can add tele- or wide- conversion lenses for greater magnification or wider field of view, as well as protective and special effect filters.
• Cyber-shot Station™ Dock Compatible
Make transferring images and recharging the DSC-P200’s battery easier with the optional Cyber-shot Station™ camera dock. Just place the camera on the cradle for instantaneous power and computer connections.
• PictBridge™ Compatibility
Connect to any PictBridge™ compatible printer with the supplied USB cable and print directly from the camera. Images can be viewed and selected for printing right on the camera’s LCD, with menus for print quantity, date and index print.
• Rechargeable InfoLithium® Battery
Provides reliable, long-lasting power for continuous shooting, without “Memory Effect". The supplied AC-LS5 adapter/charger provides stable power for USB Transfer.
Please bump it up if you check it out
m1chael322
Jul 7, 2008 05:49 AM
EddiEEchung
Dec 3, 2007 10:10 PM
