Fender Eliminator for 600rr....
Old Jun 1, 2005 | 08:02 AM
skoalking's Avatar
Default Fender Eliminator for 600rr....
Would it be hard to rig up a fender eliminator for my 04 600rr. Im just trying to get the majority of the plastic out of there...and just use the stock tails for now.
Old Jun 1, 2005 | 08:15 AM
backlash's Avatar
Default Re: Fender Eliminator for 600rr.... (skoalking)
Quite a few people on 600rr.net have made their own FE kits with parts from Home Depot, only costs a couple bucks.
Old Jun 1, 2005 | 08:30 AM
skoalking's Avatar
Default Re: Fender Eliminator for 600rr.... (backlash)
is it easier to remove or cut off part of the fender?
Old Jun 1, 2005 | 08:53 AM
backlash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skoalking &raquo;</TD></TR><TR><TD CLASS="quote">is it easier to remove or cut off part of the fender?</TD></TR></TABLE>
That I don't know (or remember), try doing a search over on that board, there should be tons of info avail to you. Unless some 600rr owners want to chime in here.
Old Jun 1, 2005 | 09:04 AM
backlash's Avatar
Here is a link http://www.600rr.net/vb/search.php?searchid=55366
Just did a search for fender eliminator HTH
Old Jun 1, 2005 | 09:10 AM
skoalking's Avatar
thanks
Old Jun 1, 2005 | 10:40 AM
Odiedogcx's Avatar
AIRBORNE
i have a banged up comepeition werkes i'd sell for chhhhhhhhhhheap. You could make it looks good really easy, or use the parts to make your own FE.
Old Jun 1, 2005 | 11:19 AM
Rhino-RR's Avatar
You just remove the whole tail section and unbolt the whole fender.That way you don't have to ruin it and it's very easy.
Old Jun 1, 2005 | 11:30 AM
JoshRambo's Avatar
Default Re: (Rhino-RR)
When i made mine. I just took a piece of metal and cut and bent it to fit where the reflectors go. I drilled out the reflector holes and bolted it down. I first used my signals for the bolts, but have since remover my signals and integrated them into the tail. I also bought some plate lights that bolt up to the bracket to hold the plate on.
this is really the only picture i got right now.
Old Jun 2, 2005 | 12:20 AM
.Ash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash &raquo;</TD></TR><TR><TD CLASS="quote">Quite a few people on 600rr.net have made their own FE kits with parts from Home Depot, only costs a couple bucks.</TD></TR></TABLE>
mine cost me 56 cents....
Old Jun 2, 2005 | 07:00 AM
backlash's Avatar
Default Re: Fender Eliminator for 600rr.... (.Ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash &raquo;</TD></TR><TR><TD CLASS="quote">mine cost me 56 cents....</TD></TR></TABLE>
Looks good to y0
low_and_slow
Paint and Body
Mar 25, 2010 07:39 PM
i_VTEC
Sep 15, 2008 03:24 PM
Kyoto now
Jun 14, 2006 01:01 PM
sublimnal
Oct 27, 2003 07:12 PM
96hb
Aug 21, 2003 10:00 AM
