I have a red Schroth Rallye-4 Harness for sale. DOT approved Pass side
I have a red Schroth Rallye-4 Harness for sale. DOT approved passenger side
It was used in my passenger seat so its like new...very little use...never in accident.
no roll cage or harness bar is needed. It just bolts into the rear seatbelt anchor points. & it can be unclipped so you can still use the back seat.
easy way to save $50-$100 if you were planning on getting the set.
SOME INFO:
The Schrothe Rallye 4 is designed for the enthusiast who is looking for a DOT approved 4 point, 2" wide harness with the simplicity of a traditional push button release. It is equipped with Schroth's unique asm® system, which reduces the risk of submarining. A quick-release buckle enables you to disconnect the tail strap, allowing occupants easy access to rear seats when the harnessbelt is not in use.
This harnessbelt is designed to mount to the two stock rear seat lap belt anchor points (the 'D' and 'E' points). It MUST be installed with a SCHROTH tested and approved seat which includes most stock seats having a single or dual post adjustable headrest and nearly all aftermarket 'racing' seats.
check these sights for details Retaills for $150+
http://www.soloracer.com/schroth.html
http://shopping.yahoo.com/sear...ked=1
asking $100
SOME INFO:
asking $100
trevorjohn88ef
Jul 19, 2008 04:09 PM
MintyDip
36
Jul 13, 2002 11:48 AM
