spark plug gap?
Old Feb 7, 2002 | 10:03 PM
infamousALLMTR's Avatar
Default spark plug gap?
is all honda/integra spark plug gap the same .44 or is there a diff. for a 92 civic. help appriciated.
Old Feb 8, 2002 | 01:17 AM
carsaregood's Avatar
Default Re: spark plug gap? (Redracinghart)
just to be super ****, the gap is .044 inches, not 44 hundreths.
but what you can do to make sure of the gap for '92 civics is consult a repair manual, or just call up a local kragen or autozone and ask. On their computers, they can look up plugs for your car, and there are normally notes that indicate the gap.
Old Feb 8, 2002 | 10:30 PM
Gasoline Fumes's Avatar
Default Re: spark plug gap? (carsaregood)
Isn't 1.1mm so much easier?
Old Feb 9, 2002 | 08:00 AM
Cuong-nutz's Avatar
it says in the chilton manual for 92 civic 0.039-0.043 in.
iono if that helps you
Old Feb 9, 2002 | 09:18 AM
Eggman's Avatar
should the gap change on a high comp motor? or turbo?
Old Feb 10, 2002 | 12:07 PM
deepnite's Avatar
Default Re: spark plug gap? (Eggman)
the gap stays the same but u need a colder plug
Old Sep 29, 2003 | 05:39 PM
USDMMARK's Avatar
Default Re: spark plug gap? (deepnite)
what would happen if you ran it say at .035 instead of .039 or .043
would that smaller gap make a diff
Old Sep 29, 2003 | 05:48 PM
EL Vap133's Avatar
Default Re: spark plug gap? (Gasoline Fumes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gasoline Fumes &raquo;</TD></TR><TR><TD CLASS="quote">Isn't 1.1mm so much easier? </TD></TR></TABLE>
Works for me....
sickofitall1113
Jun 6, 2005 11:48 AM
smikeL
Mar 10, 2005 10:02 AM
