Have any of you ever got this done???
Found this at http://www.hondaautomotiveparts.com/packs.htm. I'm wondering if yu guys have ever had this done at a Dealer...how much did you pay and did you notice a huge difference? I think I want one so I'm looking for your input...thanks!
Major Service Interval
Mileage: 30,000 - 60,000 - 90,000 - 120,000 - etc.
* Engine oil and filter - replace
* Fluid levels - top off all
* Lube hinges, locks, latches, and hood cable
* Front / Rear brakes - visual inspection
* Transmission fluid - drain & refill
* Lights - check operation
* Clutch - adjust if applicable
* Battery posts - inspect & clean
* Fuel lines, tank, lines & connections - inspect
* Spark plugs - replace (except platinum plugs)
* Distributor cap & rotor - inspect
* Tires - balance rear tires and rotate to front; adjust pressure & inspect tire wear pattern
* Coolant system - Check level & test protection
* Wiper blades - check operation & wear
* Park brake - adjust & lube as needed
* Front/Rear disc calipers & hoses
* Air filter - inspect
* Exhaust system - inspect
* Suspension, struts & steering - inspect
* Adjust valve clearance if applicable
* Brake Fluid - replace and bleed system
Call the dealers in your area and ask them how much they charge. There's usually not a big difference (among dealers, that is) in price, if any.
You may or may not feel any kind of difference. If you notice, most things are "inspect", "adjust if needed", "replace as needed"... You may not need most of it. Now, if one of those items on your car DOES need attention and you're not aware of it yet, then yeah, it might make a difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilman4o8 »</TD></TR><TR><TD CLASS="quote">if you live near the bay area, come by san jose, i'll do that for a very cheap price</TD></TR></TABLE>
I would but I'm in Memphis, TN. Thanks tho. I'll post the prices when I call tomorrow, I work all damn day ha ha. Later.
t<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">If you notice, most things are "inspect", "adjust if needed", "replace as needed"... You may not need most of it. Now, if one of those items on your car DOES need attention and you're not aware of it yet, then yeah, it might make a difference.</TD></TR></TABLE>
^werd. does anyone here live in tennesse? help a brother out, could save 200-300 bucks to just have someone help him inspect if anything needs replacing. everything on that list can be inspected and/or replaced quite simply, it only takes a few minutes for someone who is knowledgeable.
swisher man, you can do all of this stuff with about 30mins of training, minus the brake lines, fuel lines, and valve clearance. do let us know what the prices are, im interested to know as well. gl
it is a regular maintanance schedule price varies from shop to shop from city to city from state to state ,,,,that service goes anywhere from 260 t0 330 depends where you live
they will definitely rape u at da dealers... find an alternative or hell just DO IT urself! i'm sure if u searched u could find a step by step procedure on all of the above
miguey310
13
Jul 19, 2009 04:06 PM
io_burn
Aug 20, 2003 02:29 AM
