3.2 honda passport engine
Old May 31, 2005 | 08:20 PM
jesterondirt's Avatar
Default 3.2 honda passport engine
just recently had my fiances engine rebuilt in her honda passport, after installed only cylinders 1,3,5 were running, we immediately thought that the passenger side cam gear was out of time. after resetting the timing put back together and it still is doing this, we hooked it up to a computer and all we get is multiple cylinder misfire in cylinders 2,4,6. any help would be appreciated thanks
Old May 31, 2005 | 08:29 PM
Jim Truett's Avatar
Default Re: 3.2 honda passport engine (jesterondirt)
I'm not too familliar with the Isuzu motors, but if it has coil packs, is one bank defective or unplugged?
Old May 31, 2005 | 09:13 PM
littlej72's Avatar
I'm assuming you did this yourself. The procedure for setting cam timing on the DOHC engines is very complicated and time consuming as the cams are basically spring loaded, if it is sohc its pretty basic, I can look in a OEM manual for the actual procedure but I don't remember it being that odd. which set up do you have and do you have an oem manual. By the way, hopefully you have figured out that it is not a honda.
Old Jun 1, 2005 | 11:52 AM
im not too familiar with how the cams themselves are timed but we never removed them, i had the machine shop set the timing of the cam gears(not saying wether he is right or not but definitely knows more than i do)does this problem sound like a timing issue or could it be something else?
vtec8200
Feb 17, 2016 08:32 AM
TheEngine_er
Honda Civic (2001 - 2005)
Nov 17, 2014 08:54 AM
skeenr
Apr 27, 2010 07:25 PM
Disposition
Mar 16, 2008 05:56 PM
NonovUrbizniz
10
Feb 9, 2004 01:41 PM
