main relay?
Old May 31, 2005 | 06:24 PM
88da3's Avatar
Default main relay?
just recently the weather has gotten noticeable warmer and my car has been acting up. sometimes as soon as i start the car it would bog out for couple seconds and then die. i would try to start it but the pump will not prime until a couple tries. after that everything is good. thinking about when i heard about how honda main relays sometimes go bad when the weather gets warmer but not to sure. let me know what i sould do or what could be causing this so i know whether or not to buy a new relay. thanks.
Old May 31, 2005 | 09:26 PM
littlej72's Avatar
Default Re: main relay? (88da3)
90% of main relay problems are due to bad solder joints, to eliminate it as the cause, either replace it, or just remove it pop off the plastic cover and use a magnifying glass to inspect the solder joints, they will have separations like outlines in the joint if its bad.
greyEG
Jun 28, 2013 01:59 PM
hondatuner020
Audio / Security / Video
May 18, 2010 11:15 PM
8dxhatchy8
35
Feb 16, 2009 06:49 PM
turbocivic1984
Jun 29, 2008 09:59 AM
SOHCwarrior
Jul 4, 2005 05:40 PM
