Nothing I can do to remove CODE 6!
Old May 31, 2005 | 06:16 PM
NotPhilTran's Avatar
Default Nothing I can do to remove CODE 6!
91 honda crx si
b16 obd o pr3 ecu
hondata 2b
hasport wiring harness
NOTHING I can do to remove that damn code 6. ECT engine coolant temp sensor. I have tried everything I can think of. anyone out there know ANYTHING ab out this stupid code and how to make it go bye bye? I tried searching!
No dyno until code goes bye bye.
thanks to anyone that tries to help, I am so frustrated.
Old May 31, 2005 | 06:18 PM
Crx Jimmy's Avatar
Default Re: Nothing I can do to remove CODE 6! (NotPhilTran)
maybe there is a break in the wire did you check it from sensor to ecu harness for continuity?
Old May 31, 2005 | 06:34 PM
Default Re: Nothing I can do to remove CODE 6! (Crx Jimmy)
yes sir I did.
continunity is there.
Old May 31, 2005 | 06:37 PM
Is there any way someone could show me a complete wiring diagram from ecu to plug for the ect sensor?
that would be a help, all i have is what i have found on h-t and in my helms.
Old May 31, 2005 | 06:54 PM
tc_gts's Avatar
ok... here we go step by step...
-check if light is on... make sure its code 6
-reset ecu
-is engine check light still on...? if not the problem is intermitant check connections..
-if light still on warm car up till fan comes on then dissconnect the senor and messure the resistance should be 200-400ohms (if not replace the sensor)
-turn igniton on
-if its on messure volatage between red/white wire and ground..(should be 5volts)
if not problem in that wire repair it..
-if on messure voltage between red/white(+) and green(-) terminal(should be 5volts) if not around 5 volts repair that wire that goes to ecu c12
if nothing fixes ur problem replace ecu with known good one
Old May 31, 2005 | 07:32 PM
Default Re: Nothing I can do to remove CODE 6! (tc_gts)
thats exactly what my helms says
Old May 31, 2005 | 07:34 PM
tc_gts's Avatar
do it and ull solve ur problem
trust me....
unless you have been fiddling wit ur wiring or something theres no reason not to be able to solve ur problem...
Old May 31, 2005 | 07:35 PM
true, i think my wiring is fucked up from being messed with.
what pin is it on the ecu? maybe i can just rewir it.
Old May 31, 2005 | 07:36 PM
tc_gts's Avatar
c12 if im not mistaken
Old Jun 1, 2005 | 01:14 PM
hmm does anyone know how to hard wire from the ecu?
Old Jun 1, 2005 | 02:46 PM
xci_ed6's Avatar
if you didnt know what pin it was on the ECU, then you didnt follow the trouble tree.
the only thing the flowchart can't find is a damaged pin at the ECM, ECM plug, sensor, or sensor plug, unless you are using the correct test harnesseslike the dealer.
Old Jun 1, 2005 | 08:25 PM
tc_gts's Avatar
Default Re: Nothing I can do to remove CODE 6! (krustindumm)
well its pretty simple
you cut the pin wit some room to wire and solder or you remove pin and make whole new wire but go throught the steps and i bet its just a bad sensor
backwood1
Sep 6, 2018 10:30 AM
Cln94EG1
Jun 6, 2008 05:27 PM
kimo98GSR
Jun 30, 2004 09:51 PM
daniel_jian
Jun 27, 2004 11:07 AM
THE94GSR
Jun 25, 2004 05:07 AM
