b18c swap
Old May 31, 2005 | 04:06 PM
dc4R's Avatar
Default b18c swap
ok, swapped a jdm b18c 98' itr into my 96' LS non-vtec.. Been drivin it w/o VTEC. Having wiring complications for the most part. But I just found out that my jdm doesn't come with a pressure switch. I'm using the p73 ECU that it came with.... now.... Please, will someone help me out with what I have to do to get this VTEC kickin in. I've looked all over the www. no dice. I would be so greatful and appeciate any help. Thank you.
Old May 31, 2005 | 05:14 PM
HARI.'s Avatar
Default Re: b18c swap (swerveB18C5)
the pressure switch is built in the jdm ecu. did you already try wiring the vtec straight to the ecu??
Old May 31, 2005 | 11:21 PM
Manny's Avatar
what wiring harness are you using?
Old Jun 1, 2005 | 06:49 AM
dc4R's Avatar
Default Re: b18c swap (Manny)
whatever it all came with. i assumed everything shouldve been plug and play, but since my LS was a non-vtec i'm not sure what to do
Old Jun 2, 2005 | 05:50 AM
Manny's Avatar
if you are using your stock ls wiring harness you need to get it wired up for vtec.
Hayden_Fourroux
Feb 2, 2016 09:01 PM
aeros
May 5, 2009 12:25 PM
PatrickGSR94
Aug 14, 2003 07:42 AM
EKen9
Jul 4, 2002 07:18 PM
