HELP! B20 Vtec Parts list NEEDED! SEARCHED!!! my FIRST motor!
Can you people help me, im building my first motor i got the money to buy all the ****... i jusy need a list of what i need... not like mounts, head, block....
More like, what kind of starter, water pump, timing belt, all that ****.... axles, dizzy, shift linkage, wire harness (can i make one from my stock dx wire harness?) i need A WHOLE LIST!!
imma do a b20 block (might swap pistons out for higher cr), b16 head (obd1), GSR tranny
help me... shoot me links... whataver you got... part numbers... everything!!!
WHAT I GOT SO FAR...
- Starter from a gsr, distributor from a 2000 civic ( depending on what year your car is and what obd your keeping )
- all obd2 oil pumps are the same whether it be ls/rs/gs/gsr or itr there all the same whoever the water pumps are not all the same you should run a gsr or itr water pump and use the gsr or itr timing belt the b18cs have a different number of teeth on the water pump
- you're gonna need a oil feed for vtec
- use your stock wiring harness. Add the extra wires you need and Pin the ecu. You will need to add these wires.
Vtec Pressure switch
Vtec Sen.
Knock Sensor
2 O2 sensor
Modified by 1slowEK at 7:05 PM 6/20/2005
Vtec Sen.
Knock Sensor
2 O2 sensor
Water pump, from a type R or gsr
Oil pump from a type R or gsr, ( keep the water pump and oil pump from the same vehicle )
And I'm pretty sure a type R or gsr timing belt will work, depending on what you choose up above.
can i use a type r oil pump gear? or do i have to use the whole oil pump? also.. what kind of wire harness am i lookin to use? im going to use a B16 OBD1 head...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowEK »</TD></TR><TR><TD CLASS="quote">can i use a type r oil pump gear? or do i have to use the whole oil pump? also.. what kind of wire harness am i lookin to use? im going to use a B16 OBD1 head...</TD></TR></TABLE>
What year is your car ?
Also I'm pretty sure you could use the pump gear but don't quote me on that.
You guys do know the search option will answer all these questions right.
But I'm reading that all obd2 oil and water pumps are the same, from the b20, itr, and gsr and b16. But thats only what I'm hearing.
i tried searching, but i was REALLY wondering what wire harness to use... i am going to have an obd1 head.... b20z obd2 block... i actually have a whole obd1 b16a... can i use anything off of that? also i was reading abotu oil squirters and ****... and the b20 dont have them.. can i take them out of the b16 and put it into the b20?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowEK »</TD></TR><TR><TD CLASS="quote">i tried searching, but i was REALLY wondering what wire harness to use... i am going to have an obd1 head.... b20z obd2 block... i actually have a whole obd1 b16a... can i use anything off of that? also i was reading abotu oil squirters and ****... and the b20 dont have them.. can i take them out of the b16 and put it into the b20?
What ecu are you gonna run ?
i should of added that to the list too... what should i run? i was thinkin p28 cause i wanna do the hondata down the line... and im actually getting a obd2 head... and i will have a 99 b16 block for sale...
[ also i was reading abotu oil squirters and ****... and the b20 dont have them.. can i take them out of the b16 and put it into the b20?
[/QUOTE]
No u cant use the oil squirters..unless u get some custom machine work done to the b20 block
[/QUOTE]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec »</TD></TR><TR><TD CLASS="quote">[ also i was reading abotu oil squirters and ****... and the b20 dont have them.. can i take them out of the b16 and put it into the b20?
No u cant use the oil squirters..unless u get some custom machine work done to the b20 block[/QUOTE]
thanks man
thanks man
