heeellllpppppppppp to all ecu experts!!!!!!!!!!!
Old May 31, 2005 | 02:44 PM
arielmalespin's Avatar
Default heeellllpppppppppp to all ecu experts!!!!!!!!!!!
ok this is the deal i got a 94 ex coupe, the computer i got i a p28 but for automatic and it gives me code 19 for lock up solenoid ok and it idles bad like if it was the IAC. Now i bought a computer suppose to be a p28 chip and the only code i get in the new computer is code 23( knock senson), but it idles perfect. So my friends has a b16 with a p30 ecu, i put his p30 in my car and no codes i put my ecu the one that chip and he gets code 21 or 31 i forgot.
So can someone help me and also i wanna know if the d16 i got has a knock sensor? thanks a lot for any info.
Old May 31, 2005 | 02:57 PM
DJ_SaNdOz's Avatar
Default Re: heeellllpppppppppp to all ecu experts!!!!!!!!!!! (arielmalespin)
P28'S don't use knock sensors AFAIK, so the chip that you purchased may be looking for that when it's not there.
Old May 31, 2005 | 03:06 PM
Default Re: heeellllpppppppppp to all ecu experts!!!!!!!!!!! (DJ_SaNdOz)
OK DOES THE P30 MY FRIEND HAS IN HIS B16 USE A KNOCK SENSOR?
Old May 31, 2005 | 03:16 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielmalespin &raquo;</TD></TR><TR><TD CLASS="quote"> i wanna know if the d16 i got has a knock sensor? </TD></TR></TABLE>
No
Old May 31, 2005 | 03:40 PM
hatchi's Avatar
if you have a chipped p28 usually it eliminates knock sensor
Old May 31, 2005 | 03:42 PM
JDMlyfestyle's Avatar
just get a Unmodded p28 to run your D series.
Old May 31, 2005 | 03:45 PM
Hybrid96EK's Avatar
Default Re: heeellllpppppppppp to all ecu experts!!!!!!!!!!! (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">if you have a chipped p28 usually it eliminates knock sensor</TD></TR></TABLE>
That only depends on the program that is on the chip. Not all of them disable the knock sensor..
Plain and simple, NO the P28 will not support knock..
YES, the P30 WILL support knock. All the DOHC Vtec ecu's will support knock.
NO, your engine does not have a knock sensor.
YES, the chip you are trying to use is looking for the knock sensor.
Do you want to sell that automatic P28? Let me know
LUDEcidDream
Engine Management and Tuning
Jul 19, 2010 02:01 PM
CR_VtecCRX89
15
May 19, 2005 07:17 PM
E-brake or Handbrake
Jun 15, 2004 11:58 AM
stRodda
Apr 2, 2004 12:11 PM
gaydm.accord
Mar 8, 2004 03:53 PM
