99 Accord MIL==ON, OBD2 code:P1164, need help fixing this issue
Old May 31, 2005 | 01:37 PM
angrybull's Avatar
Default 99 Accord MIL==ON, OBD2 code:P1164, need help fixing this issue
58K miles on the accord and the MIL came on.
The loaned OBD2 scanner from Autozone reports the following error code twice:
P1164
The message is something liek: Manufacturer's control Air Fuel ....something like that.
I guess the error code is good enough to kind of narrow down the issue....btw, i believe that the MIL turned on while i was driving the car normally the way i do.
What can be wrong? How much will the parts cost? I would like to fix it myself and save me some money. I am not a auto mechanic but definitely am the curious types looking for a project over the weekend.
Old May 31, 2005 | 02:25 PM
Accord95Lxxx's Avatar
MIL? do you mean check engine light
Old May 31, 2005 | 02:29 PM
angrybull's Avatar
Default Re: (Accord95Lxxx)
yes
philadd's Avatar
MIL = malfunction indicator light, or something like that... same thing as CEL.
P1164 = Primary heated O2 sensor circuit range malfunction.
Sounds like you need a new O2 sensor.
EDIT for elaboration:
Prices vary for O2 sensors, depending on if you go with OEM, universal, Bosch, etc. Expect anywhere between $40 and $125 (?), depending on which you go with. It's relatively easy to change yourself. You can rent/borrow an O2 sensor socket from Autozone for a fully-refundable deposit. The sensor is located at the bottom of the exhaust manifold. You can see it sticking out towards the passenger headlight...
Dueywiththej30
Oct 31, 2015 08:08 AM
lilskydiver
Apr 23, 2012 08:22 PM
cholder919
Oct 19, 2011 12:41 AM
bryyce62
Mar 22, 2011 05:17 PM
lou805
Nov 25, 2008 08:05 PM
