Near Stock b20 dyno with gsr head itr cams
Old May 31, 2005 | 01:07 PM
GradyDC5's Avatar
Default Near Stock b20 dyno with gsr head itr cams
GSR head reworked with 310 injectors, 01 itr cams, skunk2 manifold, dc header 4into1 ,and aem itr intake.
B20 block stock compression with golden eagle head studs, arp rod bolts, type r oil pump, gsr water pump and oil line kit.
184.92 so round that up to 185 and 144 ftlbs of torque.
Modified by ReallySlowEg at 11:25 PM 5/31/2005
Old May 31, 2005 | 02:02 PM
menkio's Avatar
Default Re: Near Stock b20 dyno with gsr head itr cams (ReallySlowEg)
mm drop some new slugs in that, port the head out... mmmm mmm mm
Old May 31, 2005 | 02:08 PM
ri_rv's Avatar
what kind of EMS are you using?
on the whole setup and dyno
Old May 31, 2005 | 02:13 PM
unknown0001's Avatar
Default Re: Near Stock b20 dyno with gsr head itr cams (ri_rv)
Very nice #'s
Old May 31, 2005 | 02:16 PM
GradyDC5's Avatar
It seems the picture has vanished. I'm using hondata s200, and that was a dyno jet dyno. I wish I would've put a bigger piston now. Oh well life goes on.
Old May 31, 2005 | 05:27 PM
EG6R's Avatar
Default Re: (ReallySlowEg)
Thats really good for a stock block B20.
Old May 31, 2005 | 06:56 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (EG6R)
Torquey!
You running those ITR cams with stock B20 valve reliefs?
Old May 31, 2005 | 07:03 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">You running those ITR cams with stock B20 valve reliefs?</TD></TR></TABLE>
Couldn't have said it better. Stock GSR cams have piston to valve issues, I'd invest in some pistons (and possibly some new valves) as soon as possible.
Old May 31, 2005 | 07:20 PM
ninjaEF's Avatar
Default Re: (Kendall)
isn't stock b20 intake valves 31mm?
gs-r 33mm???
Old May 31, 2005 | 07:47 PM
builthatch's Avatar
MiG-21 superfan
get an SMSP header and watch those numbers get quite a bit fatter.....
https://honda-tech.com/zero...age=7 ...read my post at the bottom.
Old May 31, 2005 | 10:50 PM
GradyDC5's Avatar
Homemade Valve Reliefs :: HAHA! This car has been run to death 50 plus dyno runs, and many times at the track. I'm not bragging or anything, but it's my workhorse. The RSX is my weekend car I drive this car to work 4 days a week.
Old Jun 1, 2005 | 04:12 AM
Adam.'s Avatar
Damn, these b20vtecs are really making some power easy.
Old Jun 1, 2005 | 07:34 AM
Rollo Lawson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
Stock GSR cams have piston to valve issues, I'd invest in some pistons (and possibly some new valves) as soon as possible.</TD></TR></TABLE>
ummmmmm.....no. gsr cams are fine with stock b20 valve reliefs. actually, b20's are fine with ITR's as long as you don't **** with the cam timing.
Old Jun 1, 2005 | 11:51 AM
ItsSlow's Avatar
Too bad you can't find 15 more horsepower. It's fun to ride in though!!
Old Jun 6, 2005 | 04:49 PM
GradyDC5's Avatar
I've got whatever the stock compression is for a jdm b20b block. So, would a better header .. that rhymes benefit even though i've got crap for compression.
Also, i've been looking at these diy itb setups and wondering.
Old Jul 28, 2005 | 04:32 AM
prodigalson's Avatar
Default Re: (B16C1)
Are the B20Z pistons ok to use with GSR cam (assuming no cam timing changes). I am under the impression that the B20B is a lower compression engine, so smaller dome on the pistons, so I can see how that would be ok, but what about the B20Z?
Old Jul 29, 2005 | 01:00 PM
timisyourfriend's Avatar
Default Re: (prodigalson)
Either way, it's a scary thought, so just buy cheap pistons. Stock rods work great. (=
good job on the build, for the creator of this thread.
Old Jul 29, 2005 | 07:55 PM
EK Josh's Avatar
Default Re: (JZPerformance)
Nice graph.
Old Jul 30, 2005 | 06:54 AM
DIFFUT'S INC.'s Avatar
Default Re: (GGhatchie)
Old Aug 6, 2005 | 10:38 AM
Circuit Star-29's Avatar
Nice #s...once you get your A/F leveled out you should see a bit more power and torque...
Old Aug 6, 2005 | 01:51 PM
sleepycivichb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReallySlowEg &raquo;</TD></TR><TR><TD CLASS="quote">I've got whatever the stock compression is for a jdm b20b block. So, would a better header .. that rhymes benefit even though i've got crap for compression.
Also, i've been looking at these diy itb setups and wondering.</TD></TR></TABLE>
I'm currently running a B20Z bottom with a b16a head milled .02" with `98 gs-r cams and it's running great. tuning hopefully soon with a couple more goodies.
pasaunde
253
May 2, 2020 05:19 PM
helloars
41
Sep 3, 2015 08:51 PM
slowsleeper
47
Sep 3, 2013 10:48 AM
egboy94
Oct 19, 2010 07:03 PM
TwistedHatch
19
Oct 25, 2003 11:34 PM
