b16a wont go into vtec
Old May 31, 2005 | 12:12 PM
xDicktonesx's Avatar
Default b16a wont go into vtec
id appreciate it if you could help me out,
my vtec solenoid was leaking a little oil from the gasket on top. i pulled it off, put the gasket back in after i found it would take a few days to get it from a honda dealer. now the car wont go into vtec. what did i do? everything is exactly the way it was before and everythign was fine then. i thought maybe i got a little piece of gasket in the little channels for the oil but i cleaned it out well. spotless.
it goes into vtec for about the first 3 minutes after i turn the key and drive off, then nothing
Old May 31, 2005 | 12:26 PM
dkboyny11's Avatar
Default Re: b16a wont go into vtec (CRXofPain)
Put a wire in the blue connector to complete the connection under the passenger side of the dash. That will make the codes pop up on the dash by watching the check engine light. See what codes you have first and then diagnose the problem from there.
Old May 31, 2005 | 12:32 PM
insomniac791's Avatar
Default Re: b16a wont go into vtec (dkboyny11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkboyny11 &raquo;</TD></TR><TR><TD CLASS="quote">Put a wire in the blue connector to complete the connection under the passenger side of the dash. That will make the codes pop up on the dash by watching the check engine light. See what codes you have first and then diagnose the problem from there. </TD></TR></TABLE>
this is not how you do it on a crx. Just pull the carpet back on the passenger side foot wheel and turn the key on to acc. there will be a little red light blinking on your ecu just count the blinks
long blink=10 short blink=1
Matt
Old May 31, 2005 | 12:49 PM
dkboyny11's Avatar
Default Re: b16a wont go into vtec (insomniac791)
Sorry he didn't specify OBD0 or OBD1, my bad
I used to have that ECU, just upgraded to OBD1.
Old May 31, 2005 | 05:31 PM
no problem
Old May 31, 2005 | 07:53 PM
kid-crx's Avatar
try reseting the ecu
Old May 31, 2005 | 08:04 PM
tallguy's Avatar
Hey you can join my club ( the non vtec b16 club) well my vtec is like a woman it only works when it feels like.
Old May 31, 2005 | 08:15 PM
krazie1's Avatar
BANNED
Default Re: b16a wont go into vtec (tallguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallguy &raquo;</TD></TR><TR><TD CLASS="quote">Hey you can join my club ( the non vtec b16 club) well my vtec is like a woman it only works when it feels like. </TD></TR></TABLE>
this could be a wire not making contact only when u gun it to make the contact???
I had this happend black tape ain't always good to use soldering is always best
Old May 31, 2005 | 08:22 PM
tallguy's Avatar
Default Re: b16a wont go into vtec (krazie1)
yeah i took some time off of work next week so that i can remove the harness and thoroughly inspect it end to end.
Old Jun 1, 2005 | 12:17 PM
well it was throwing code 22 of course. i got a new gasket for the solenoid. when i tightened it down, the solenoid broke in half. i snagged a single cam vtec solenoid (top half) for $0. will it work? the gasket surfaces is slightly different.
honda gsr01
May 19, 2008 08:53 PM
xDicktonesx
Jun 3, 2005 11:50 AM
xDicktonesx
May 31, 2005 12:23 PM
type Gendy
Apr 2, 2003 01:17 PM
