HELP!!-----DIPPING/LOW IDLE----did search...
repost..need feedback...
sup guys, my b18c1 was rebuilt a couple thousand miles ago....during break in the motor ran great....
i recently installed a 190 walbro pump and 310cc injectors ( in a eg chassis)...
after the install, or shortly thereafter, the car started to act up.
the idle holds fine..when it wants to...at 700-750 rpm...then sometimes in the 500 rpm range...
when i drive...and come to a stop...it dips in the 500 range as well...then struggles its way back up.
when i start her up...its not a crisp clean start up like usual...theres a bit of struggle there as well..
the motor is strong, did a compression ttest and the numbers are great.
the only thing(s) changes are the injectors and pump....i'm running a chipped p28 currently...
the research i have done is to check the 02, iac valve, clean and check t/b, air filter, plugs etc...
i'm wondering if i'm running way rich???
fpr reads at 42 psi at idle...
any info or feedback will be greatly appreciated...
thanks
thanks
i just installed the injectors to tune this week....but the tuner is booked til next thursday....almost 2 weeks...just wondering if my car is safe to drive...daily...til then
protopro88
Apr 12, 2011 10:59 PM
crx1856
Aug 29, 2003 11:04 AM
