cold motor bog
Old May 31, 2005 | 12:06 PM
22lude's Avatar
Default cold motor bog
Ok when the motor is cold, sat for 3 hours or so, it bogs down heavily under acceleration, until it warms up.I know.... let it warm up first, and so i have, but i think another problem im having is related to it . When the car is as warm as its gonna get, between 2800 and 3200 rpm the exhaust pops under slow acceleration . it doesent do it when giving it about 30% throttle or more but say 15% and under it starts laging/popping/backfiring pretty badly. the things ive checked and fixed are the fuel filter,cap and rotor, timing, plugs and wires. Im kinda at a loss... maybee wondering if anyone else has run into the same problem the only things I can think of to check next would be injectors and maybe the fuel pump ???//// Help me please this is getting rediculous!!
H22 JDM
Old May 31, 2005 | 12:15 PM
Monkey Fing a Coconut's Avatar
Default Re: cold motor bog (22lude)
if it can work fine while pumping more fuel, its not going to fail pumping less fuel...
Old May 31, 2005 | 12:25 PM
22lude's Avatar
Default Re: cold motor bog (Monkey Fing a Coconut)
Well when I had it dynoed there was a drop in power between 28 and 3800 rpm's( he also felt this bog im talkin about. the guy who was doing it, and also owns the shop, was the one who replaced the fuel filter as well as checked the timing and rotor. he was at a loss as well. One thing that did help was when i was doing the swap i bent the line that comes from the fuel filter a little bit. I replaced that with a high press hose and it seemed to help but its still not fixed. Any ideas?????????
Old May 31, 2005 | 12:33 PM
22lude's Avatar
http://www.92lude.com/fpr_mod.htm
I also did this and it helped out even more
Old Jun 1, 2005 | 07:28 AM
darkspector's Avatar
bad injectors?
Old Jun 1, 2005 | 08:41 AM
22lude's Avatar
Default Re: (darkspector)
Yea thats pretty much what im thinkin anyone know of ay good aftermarket ones to get???
Old Jun 1, 2005 | 08:44 AM
i'd either just get new stock replacements or find someone selling them here...
Old Jun 1, 2005 | 08:45 AM
i think I need to get me some too
Old Jun 1, 2005 | 02:45 PM
BokChoy's Avatar
not to sound like i'm dumping on you ...but alot of guys have experienced this after doing a swap, myself included, I think there was a thread a while back where the guy found the problem, I suggest you quit spending money on the little things and do some hard core searching. I gave up after a while and sold the whole shibaz, wrong thing to do. Are you getting a CEL? if so is it egr? Good luck
Old Jun 1, 2005 | 02:48 PM
eMpAtHy's Avatar
Default Re: cold motor bog (BokChoy)
if you do get after market ones like lucas, rc, or any other company and they are bigger than the normal size, you are going to need to get it tuned, if not, then you are going to run rich and lose hp and waste money on gas. either get the same size, or get them tuned. if you are not going FI, then stay with the stock size. you can also get ur injectors flow tested. where at? i dont know.
Old Jun 1, 2005 | 10:18 PM
I only have 188k on my car....
Old Jun 2, 2005 | 08:07 AM
JadedGamerX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BokChoy &raquo;</TD></TR><TR><TD CLASS="quote">not to sound like i'm dumping on you ...but alot of guys have experienced this after doing a swap, myself included, I think there was a thread a while back where the guy found the problem, I suggest you quit spending money on the little things and do some hard core searching. I gave up after a while and sold the whole shibaz, wrong thing to do. Are you getting a CEL? if so is it egr? Good luck </TD></TR></TABLE>
Yes the problem has been covered before, and for one owner it was the timing that fixed the notorious "3k hesitation / bog problem".
If you own a prelude, it's famous, my 2000 Type SH even had it and that car only had 48k miles on it. However, I had no way to change the timing on my h22a4 so I had to replace the knock sensor, and that's still not gauranteed to fix the problem, however, most people have the best results fixing the "3k bog" with a new knock sensor and a new rotor.
If you would like to search the arhives it would be under "The Official Prelude Bogging and Hesitation thread".
Good luck
Old Jun 3, 2005 | 02:39 PM
BokChoy's Avatar
Default Re: cold motor bog (JadedGamerX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadedGamerX &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck</TD></TR></TABLE>
That's the thread... I asked about the egr because mine was throwing an egr code no matter what, I put a new one in, and eventually just threw in a block plate. Read that guys write up and if that doesn't work
vtec_fed
Dec 2, 2009 01:07 PM
Abomb
Sep 16, 2007 01:22 PM
430hatch
May 6, 2007 05:40 PM
KaiITR
Jun 8, 2003 01:38 PM
