0 compression, 1 cylinder
Old May 31, 2005 | 11:03 AM
Lewdin' Incognito's Avatar
Default H23vtec = 0 compression on 1 cylinder
As the title eludes to, I just finished up putting the H22 head on my H23. Got everything hooked up, tightened down, and timed. So here are the symptoms:
Cyl 1 had about 75psi compression, then dropped off to 0 and hasn't come back. Cyl's 2, 3, & 4 each are pulling 175psi.
I did a compression test on the H23 head before we tore it apart and all of the cylinders were pulling good compression (170-200) so I'm pretty sure the bottom end is OK.
The question - Since I was a dumbass and didn't have the new (used) head sent in for a valve job, do you guys think that is what my problem is?
-and-
Is there anything that I can try while the head is still on the motor, in the hopes that maybe the valves just aren't quite seating or have debris?
The Prelude runs (like ****) finally, still getting frustrated.
Old May 31, 2005 | 12:30 PM
bb_one's Avatar
Default Re: H23vtec = 0 compression on 1 cylinder (Lewdin' Incognito)
Try a leakdown test.
Have you tried adjusting your valves? 0 Compression sounds like its a major problem, and a simple valve adjustment may not fix that, but it won't hurt to try.
Old May 31, 2005 | 12:43 PM
Default Re: H23vtec = 0 compression on 1 cylinder (bb_one)
Yeah, went through and adjusted all the valves before starting up.
Haven't had a chance to do a leakdown yet.....this is a "weekend only" project 'cause the car is 200 miles away.
Old May 31, 2005 | 01:01 PM
john d
Guest
Posts: n/a
blown.
Old Jun 7, 2005 | 02:45 AM
Default Re: H23vtec = 0 compression on 1 cylinder (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">blown.</TD></TR></TABLE>
wow......nothing like an in-depth answer
Anyway, leakdown test has air hissing through the intake.....so looks like I get to have a valve job. yay.
Old Jun 7, 2005 | 11:03 AM
lude of pre 2.3's Avatar
have u found any coolant or oil leaks threw the head gasket
Old Jun 7, 2005 | 11:08 AM
eMpAtHy's Avatar
Default Re: H23vtec = 0 compression on 1 cylinder (lude of pre 2.3)
or a completely broken valve or 2?
Old Jun 7, 2005 | 11:32 AM
Default Re: H23vtec = 0 compression on 1 cylinder (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude of pre 2.3 &raquo;</TD></TR><TR><TD CLASS="quote">have u found any coolant or oil leaks threw the head gasket</TD></TR></TABLE>
No - brand new head gasket. This is the head I am replacing my H23 one with b/c it cooked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">or a completely broken valve or 2?</TD></TR></TABLE>
Adjusted all valves, and they all moved when rotating the crank. I just wish I would have taken the time to have the valves done BEFORE I put the head on.
Zohaib Ali
Apr 6, 2017 05:47 AM
Jos3ph
Jan 14, 2008 09:45 AM
zoom545
Nov 22, 2005 09:04 AM
street dreams
Nov 21, 2004 04:48 PM
