CTR grille into a stock 99 hatch
Old May 31, 2005 | 10:05 AM
PaulwitdaEK's Avatar
Default CTR grille into a stock 99 hatch
does anyone have instructions to removing a stock grill then installing a type r grille into a 99 hatch??
Old May 31, 2005 | 10:14 AM
Ricey McRicerton's Avatar
Default Re: CTR grille into a stock 99 hatch (PaulwitdaEK)
Yeah, remove the bumper, unscrew the old grilled out of the bumper and reinstall the other.
To get the bumper of you need to remove the pop fastners (or whatever theyre called) on the radiator support. There are 6 or so. Remove the screws in each fenderwell holding the bumpers to the body there. Remove the bolts on the bottom side of the bumper (around the oil pan area) holding the bumper to the splash sheilds there. Slide bumper off.
Old May 31, 2005 | 10:18 AM
civictildeath's Avatar
the grill has to be from a 99-00 or it wont fit
take front bumper off, there are 2 bolts on underside, 1 in each wheel well, and like 7 or so plastic pop tab across the top.
then there will be some screws holding the grill to the bumper which you can see after bumper is off.
JaeEK
11
Dec 7, 2007 07:22 PM
Superdragr45
Dec 25, 2003 09:12 PM
CHRIS 1.8
12
Apr 27, 2003 07:43 PM
raymondcleung
Aug 18, 2002 01:27 AM
