I think my brother bent a valve...help?
Ok guys, my brother accidently went from 3rd to 2nd @8000 rpm while running with nasa at PIR last weekend. It was his first event and was doing well until the accident happened.
It drove home fine with a little noise happening.
Then yesterday he informed me that it was making like a popping bubbling noise.
I checked the compression and these were the results.
Cylinder 1: 170
Cylinder 2: 180
Cylinder 3: 175
Cylinder 4: 150
Now I know + or - 10 is still within good standings but the 150 has got me worried.
It makes the popping/bubbling noise often now while at idle.
I am going to be tearing the head apart to see what it could possible be. Any ideas on what I should be looking for? or if any what should I upgrade while I'm in there?
thanks for any information and advice you can give me.
Cylinder 1: 170
Cylinder 2: 180
Cylinder 3: 175
Cylinder 4: 150
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1nal zeros »</TD></TR><TR><TD CLASS="quote">Now I know + or - 10 is still within good standings but the 150 has got me worried.</TD></TR></TABLE>
Gotta love the money shift.
Is that compression tester known to read well? I would have expected higher all across, but some testers read different. It's possible everything is fine, but it's possible all the valves are bent. Leakdown test might show valves.
-Chris
-Chris
same thing happened to me, hopefully i figure out whats wrong real soon and can shead some light on your situtation.
But I do reccomend doing a leakdown test
good luck!!
good luck!!
While the head is open any recommendations on what should be replaced or upgraded? This will be for a NA application.
The block has 84k miles on it so I am going to replace the oil pump, water pump, and timing belt.
Any other items I should consider replacing or upgrading?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
-Chris
umm...how can the engine still worK if the valves r bent? lol
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drifter_X »</TD></TR><TR><TD CLASS="quote">
umm...how can the engine still worK if the valves r bent? lol</TD></TR></TABLE>
If the head of the valve taps the top of the piston, they can bend just a little. They will tick louder, and not seat against the valve seat completely, and you'll get crappy compression and beat up the valve seats.
Econo'Box
Nov 11, 2014 04:36 PM
JDM JUNKIES 1
Mar 12, 2013 12:19 AM
goldpearleg6
Aug 8, 2010 05:21 PM
