Overheating problem..... i cant figure out
Old May 31, 2005 | 07:55 AM
ITR.#1446's Avatar
Default Overheating problem..... i cant figure out
I recently swapped a 94 gsr motor in my brothers 91 da....i am using a pr3 and the original obd0 harness........ever since i have finished the swap it overheats........i dont think the cooling fans are coming but if i drive it and turn the heat on full blast it goes back to normal operating temp. ....when i did the swap g2ic said i have to extend the temp switch from the back of the motor to the thermostat housing which i think i did but i ended up with an extra plug that is not plugged in to anything........does anyone know what my prob could be or what color wire the temp switch plug is???
thanks in advance
Old May 31, 2005 | 08:06 AM
ITR.#1446's Avatar
Default Re: Overheating problem..... i cant figure out (ITR.#1446)
also fans do work when i turn on the a/c but dont kick on once it reaches operating temp.
Old May 31, 2005 | 12:20 PM
ITR.#1446's Avatar
any input on my problem?
Old May 31, 2005 | 02:08 PM
projectTeG's Avatar
did you bleed the cooling system....check your radiator cap and radiator for leaks?
Old May 31, 2005 | 03:38 PM
bottlefed13's Avatar
Default Re: (projectTeG)
thermostat?
Old May 31, 2005 | 04:24 PM
ITR.#1446's Avatar
replaced the thermostat and i tried to bleed it but it didnt seem to work...........i opened the bleeder screw and it like dribbled out
Old May 31, 2005 | 04:25 PM
wilntegra's Avatar
did u flush the radiator maybe it could be clogged or check if u water pump is noy leaking.....
Old May 31, 2005 | 04:28 PM
ITR.#1446's Avatar
Default Re: Overheating problem..... i cant figure out (wilntegra)
im gonna try to flush the rad later this week........idk if the water pump is leaking but there is no puddles or anything
Old May 31, 2005 | 04:43 PM
Rs xtreme 415's Avatar
im having the same problems. except i flushed it numerous of times, and changed the thermostat. i guess my problem is the fan switch(es)
Old Jun 1, 2005 | 02:41 PM
ITR.#1446's Avatar
Default Re: Overheating problem..... i cant figure out (Rs xtreme 415)
just hardwired the fan and they work, they also both kick on with a/c on.......replaced the fan switch sensor and still doesnt come on??? it had new fluids from when i did the swap but i didnt flush the rad so idk..........im goin crazy tryin to figure this out
Old Jun 1, 2005 | 02:46 PM
JoeG86's Avatar
make a manual switch connected to the fans and wire it in ur car, turn them on whenever u want and turn them off whenever u want, my friend had the same problem and he did that.
Old Jun 1, 2005 | 03:46 PM
Default Re: Overheating problem..... i cant figure out (JoeG86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeG86 &raquo;</TD></TR><TR><TD CLASS="quote">make a manual switch connected to the fans and wire it in ur car, turn them on whenever u want and turn them off whenever u want, my friend had the same problem and he did that.</TD></TR></TABLE>go in to details.
Old Jun 1, 2005 | 05:01 PM
AlphaQup's Avatar
does your fan actually spin?
Check the little nut that hold the fan down to the fan-motor. It may have come loose.
Old Jun 1, 2005 | 08:37 PM
ITR.#1446's Avatar
Default Re: Overheating problem..... i cant figure out (AlphaQup)
yea the fan spins i just hardwired a switch and keep it running all the time and it goes to about 3/4's sometimes but seems to work
Old Jun 1, 2005 | 09:35 PM
HoUTX98GSR's Avatar
maybe your extra plug goes to your thermo fan switch... it switches the fan based on temp.. i bet the wiring for your thermo fan switch is not right.. check it.
Old Jun 2, 2005 | 01:08 AM
EnjoyTheRideDC2's Avatar
Default Re: Overheating problem..... i cant figure out (HoUTX98GSR)
I have asked for help on the same exact problems forever now. Been dealing with the same exact prob for over a year and a half now.I even went as far as taking out the AC. I've gone through 4 radiators, all of which are still on working condition. I was stupid and just kept upgrading from oem replacements to a Koyo Aluminum. My leakdown test turns up negative, pump and timing belt changed, all hoses, fans, flushed millions of times, but i think it comes down to the type of water i'm mixing my coolant with....or my timing. ****, IDK. I say go as far as checking the timing. Also, check the hoses near the intake mani.
Old Jun 2, 2005 | 08:11 AM
HoUTX98GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR &raquo;</TD></TR><TR><TD CLASS="quote">maybe your extra plug goes to your thermo fan switch... it switches the fan based on temp.. i bet the wiring for your thermo fan switch is not right.. check it.</TD></TR></TABLE>
Old Jun 2, 2005 | 08:13 AM
Nekekami's Avatar
thought that cat got angry if you clicked on it
Old Jun 2, 2005 | 11:51 AM
Default Re: Overheating problem..... i cant figure out (Nekekami)
damn integra's i still dont know what my problem is .
Old Jun 3, 2005 | 05:51 PM
bump
Old Jun 3, 2005 | 05:57 PM
WhiteGSR95's Avatar
check that plug, and ure radiator fans arent coming on?
Old Jun 3, 2005 | 09:00 PM
ITR.#1446's Avatar
Default Re: (WhiteGSR95)
fans come on with the a/c
Old Jun 3, 2005 | 09:13 PM
WhiteGSR95's Avatar
so when u turn the a/c on ure radiator fans come on? looks like u have a cross short. and a posible bad switch
Old Jun 3, 2005 | 09:29 PM
ITR.#1446's Avatar
yea only when i turn the a/c on...........i bought a switch where is it located?
Old Jun 3, 2005 | 09:33 PM
Contender25
Guest
Posts: n/a
Uh oh, i had a little puddle of coolant around the left side of the bottom of the motor on the ground, it was more to the the resevoir "spelling" area rather then the water pump area, but i din't know you'r water pump could leak...should i get it replace right away then?, would that mean it's about to go?.
