Clutch sensor wire?
I'm in the process of doing an auto/manual swap and I almost have all the parts I need except the clutch sesnor wire.
My clutch pedal the sensor already in it (it's yellow) but I still need the wire. Could anyone post a picture of the wire that I would need for this? Where does this wire connect to? Thanks.
Hey im in the process of do a manual swap also, the 2 sensors on the clutch are for cruise control disable and starter disable, neither of them need to be hooked up, and since I have auto start they really don’t need to be connected
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">Hey im in the process of do a manual swap also, the 2 sensors on the clutch are for cruise control disable and starter disable, neither of them need to be hooked up, and since I have auto start they really don’t need to be connected</TD></TR></TABLE>
I'm using a manual starter.. Will I need one then? Or will I still be able to use my automatic starter? If I use my manual, will I need to get it hooked up?
mmmtrbolude93
Jun 29, 2006 11:36 AM
