Stock fuel injectors or no?
Ok I need a little help on knowing if my stock b16 fuel injectors would be good for using on my lsvtec. I plan on raising the compression to 11.1, and putting in some skunk2 stage 2 cams in there I already have a fuel rail and fpr, and plan on getting it tuned with hondata s200. Now would the b16 fuel injectors work or should i upgrade. Thanks any info would help.
You're probably going to want a bit more fuel, and finding out that you're maxing the stock ones once the car is on the dyno is frustrating. An inexpensive upgrade would be OBD-2 Prelude injectors. Even if you could have squeezed out enough fuel with the stock injectors by running high pressure, the larger Prelude ones will allow lower pressure, which will be easier on your pump.
I can get a set of used rc 330's i belive is what he said they are from a buddy of mine for pretty decent price. I just wasnt sure what i would better off doing. As far as the fuel pump is the ls one going to be fine.
JDM turbo DC
Mar 24, 2006 05:44 PM
