Problem with Draining Coolant
Old May 30, 2005 | 11:19 PM
TUR3Ovtec's Avatar
Default Problem with Draining Coolant
Hey ok, i got a problem today i noticed that my temp gauge was gettin high, so i threw some water inside the radiator and it went down a little, now i want to drain out the coolant, and new one in...how do i do this???? i searched but all of them have to do with gettin the air out of the coolant, i need to completely take out the liquid, thanks in advance!
Old May 30, 2005 | 11:22 PM
komat's Avatar
Default Re: Problem with Draining Coolant (TUR3Ovtec)
theres a freeze plug bolt on the front and back of the motor
just unplug one of them with a 19mm (i think?)
when the bolt is out a good bit of coolant should come out
to flush it all out
stick a water hose into the radiator and watch water come out of the block
Old May 30, 2005 | 11:24 PM
TUR3Ovtec's Avatar
Default Re: Problem with Draining Coolant (komat)
Thanks alot bro, is that bolt visible, or is it somewhere i gotta look hard to find???
Old May 30, 2005 | 11:27 PM
komat's Avatar
it should be behind or near the header to the left
you may need one of the cv joint socket thing to loosen it(those adapter that lets you go at an angle)
on my b16 the bolt is to the right of the motor stamp. you should see a bolt (its pretty big you cant miss it)
Old May 30, 2005 | 11:28 PM
TUR3Ovtec's Avatar
damn, sounds like a pain...should i jus put more coolant in it tommorow, and jus watch the temp gauge from now on?
Old May 30, 2005 | 11:30 PM
komat's Avatar
if you have a b16 you wont need the angle socket thing
i would flush it out if its an old car
if you flushing it out
replace the thermostat since all the coolant is drained
Old May 30, 2005 | 11:41 PM
TUR3Ovtec's Avatar
Yeah i got a B16A, i jus got rid of my turbo setup on my LS motor like 4 months ago so the coolant shouldn't be that bad on this motor
Root of all Evil
Oct 29, 2011 09:54 AM
tico
May 11, 2009 03:16 PM
OogalyDoogaly
Honda Motorcycles
Feb 4, 2008 05:31 AM
CoolRedXylophone
Apr 30, 2006 06:59 AM
Etylorcen
Aug 15, 2002 01:24 PM
