throw out bearing
when i took out my whole engine and stuff i decided to replace my clutch and the throw out bearing... well the thing is its that when i push on the clutch pedal it seems like nothing even if i tighten the cable all the way it would still feel like nothing... i also noticed that on my cousins 90 ls that when i try to pull up on the lever/arm deal that the clutch cable is connected to it is pretty near impossible... but when i pull up on my lever it is cake.... i also remember that when i put my bearing in that there was alot of that high temp grease on the shaft... is that supposed to be there... i just think that its really wierd cause when im like on a slope and put it gear i can push the clutch in all the way and try to get it out of gear and nothing happens the only way to get it out of gear is to force it out by yanking on it really hard... also i havent been able to sart my car up yet cause of some faults in my jdm d15 swap.....but it really doesnt seem like it does anything when i push the clutch in.. so did i **** up on the throw out bearing????????
FOMULA91
May 28, 2010 07:35 PM
alscrx
Nov 3, 2008 04:27 PM
user 98292739
Feb 2, 2005 01:42 PM
