Coversion Question!!
Old May 30, 2005 | 09:58 PM
Civic92jak's Avatar
Default Coversion Question!!
sup guys. This is a rare question as not very many would do this with such motor, but heres my question:
I want to pick up and OBD 0 DOHC ZC motor and convert it to OBD 1 seeing i have a 95' EH2 hatch. Has anyone done such or know of anyone that has and could link me to a site or post that deals with such?
Also, i've heard that some of the DOHC ZC blocks do not accept the trans you find in the 5th gen civics and such. So any info regarding this is greatly appreciated.
Old May 31, 2005 | 09:41 AM
Civic92jak's Avatar
wow, knew this was a rare question, but figured at least someone would know
Old May 31, 2005 | 11:05 AM
RedZone's Avatar
Default Re: (Civic92jak)
you can do it but you might have to fab a distributor mount so you can run an OBD1 distributor, unless you can find one that bolts up and will work correctly......other then that you will need a seal for the front cam sensor, you can get this from an LS head.....that should be it...if you get the JDM ZC you will be fine with the tranny bolting up...make sure its a blacktop valve cover ZC.....
Old Jun 1, 2005 | 07:12 AM
Civic92jak's Avatar
arlight, thanks.
djphonics
Apr 18, 2006 07:28 AM
C M S
Feb 22, 2005 07:15 PM
hondaspeder
Sep 12, 2003 06:25 PM
