99-00 Si Gauge Cluster problem.
Old May 30, 2005 | 09:16 PM
BoostedJeff's Avatar
Default 99-00 Si Gauge Cluster problem.
I searched!
Ok, here's the deal. I have a 99-00 Civic Si gauge cluster in my 97 CX hatch. The car is currently going through a full rebuild, and i am all done the wiring inside except for one problem. I am not getting any illumination from the cluster.
-the blinker lights work
-the SRS light works
-the high beam light works
-everything else works
basically, i need to know why i am not getting ANY lights behind the numbers on the tach, speedo, fuel or temp gauges.
if this helps, i no longer have the dimmer switch hooked up, but I heard this doesnt matter.
PLEASE!!! ANY HELP WILL BE GREATLY APPRECIATED!!!!
Modified by BoostedJeff at 1:35 AM 5/31/2005
Old May 30, 2005 | 09:36 PM
ek9800's Avatar
Default Re: 99-00 Si Gauge Cluster problem. (BoostedJeff)
bump for jeff
Old May 30, 2005 | 10:22 PM
please ppl. i need help!!!!!
Old May 31, 2005 | 07:02 AM
DXK Eg's Avatar
it's the dimmer switch hook it back up and i bet it will work for you.
Old May 31, 2005 | 07:57 AM
Default Re: 99-00 Si Gauge Cluster problem. (DXK Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXK Eg &raquo;</TD></TR><TR><TD CLASS="quote">it's the dimmer switch hook it back up and i bet it will work for you. </TD></TR></TABLE>
do you know what the color of the wires are that go to the dimmer switch? i believe the plug is cut
bugg2zero9
Apr 5, 2013 11:13 AM
skcivic4life
Oct 24, 2007 05:36 AM
Master23
15
Apr 3, 2007 02:05 PM
EFvtec Yo!
Nov 21, 2005 06:30 PM
VoltageLS
Apr 3, 2002 10:09 AM
