Vtech Malfuntion????? P1259
Old May 30, 2005 | 09:06 PM
Leviata-N's Avatar
Default Vtec Malfuntion????? P1259
Hey people, my ECU is given me this code p1259, it says that is a VTEC malfuntion, but the only thing that I change to this car is take the CAT out (of course the ECU also said that), and connect the VAFC, so if someone can tell me what can produce this code please let me know. The car is a Honda Civic, 2000 year, SI, Coupe, with the B16A2, USA version, and the f.....OBDII system (I hate this system). Well I am ready to listen what you have to say....By the way I DO KNOW MY ENGLISH IS NOT SO GOOD, so please be nice and understand that I live in a country that speak spanish THANKS.....
Modified by Leviata-N at 6:18 AM 5/31/2005
Modified by Leviata-N at 6:40 AM 5/31/2005
Old May 30, 2005 | 09:09 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Vtech Malfuntion????? P1259 (Leviata-N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leviata-N &raquo;</TD></TR><TR><TD CLASS="quote">VTECH</TD></TR></TABLE>
VTEC...
Old May 30, 2005 | 09:15 PM
Leviata-N's Avatar
Default Re: Vtech Malfuntion????? P1259 (EJ8VTEC)
Okey good to see that you understand the bottom line....What else smarta......
Old May 30, 2005 | 09:20 PM
zeroek's Avatar
Default Re: Vtec Malfuntion????? P1259 (Leviata-N)
Code P1259?? Do you get that if you use one of those OBD2 readers? Like they have at Autozone?
Old May 30, 2005 | 09:29 PM
Verbal Intercourse's Avatar
I dont think his phone is working.
Old May 30, 2005 | 09:36 PM
Leviata-N's Avatar
Default Re: Vtec Malfuntion????? P1259 (zeroek)
I took the car to my mechanic and he plug hes laptop in a plug next to the drivers seat.
Old May 30, 2005 | 09:37 PM
JDMlyfestyle's Avatar
so you installed a VAFC into the car and you have a CEL now?
Old May 30, 2005 | 09:40 PM
Leviata-N's Avatar
Default Re: (JDMlyfestyle)
Well can you said something with sense
Old May 30, 2005 | 09:44 PM
tell me how you wired up the VAFC... did you install the VTM wire?
if you did. did you install the VTM wire off the VAFC to the ECU or into the engine harness?
Old May 30, 2005 | 09:46 PM
Leviata-N's Avatar
Nope, can you tell me what is the VTM???? Please I think my mechanic do not used, he just install the same wires than in my old OBDI
Old May 30, 2005 | 09:47 PM
so your mechanic installed the VAFC for you? im gonna need to know what wires on the VAFC he hooked up to the ecu.
i need the following
VAFC color wires connects to ECU wire color and spot
Old May 30, 2005 | 09:48 PM
Leviata-N's Avatar
Yes he did it and he said that the diagram does not appear any VTM on the ECU
Old May 30, 2005 | 09:49 PM
what ECU are you using?
Old May 30, 2005 | 09:51 PM
Leviata-N's Avatar
The standard ECU that came with the car....OBDII, ITP.
Old May 30, 2005 | 09:52 PM
i need to know what wire is going to what wire and spot on the ECU.
Old May 30, 2005 | 09:54 PM
Leviata-N's Avatar
Did you know the meaning of the letters VTM
Old May 30, 2005 | 09:59 PM
VTEC Oil Pressure Signal.
Vtec Equipped cars must have at least 55 psi of oil pressure to engage in vtec.
Old May 30, 2005 | 11:10 PM
stevenlo's Avatar
obviously the vafc is at fault here...
Old May 30, 2005 | 11:16 PM
Ignitecivic's Avatar
Default Re: (stevenlo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevenlo &raquo;</TD></TR><TR><TD CLASS="quote">obviously the vafc is at fault here...</TD></TR></TABLE>
Old May 31, 2005 | 09:10 AM
Its the vtm wire.
Old May 31, 2005 | 09:25 AM
Bcuz's Avatar
U need oil, trust me check your oil level it will be low. The VTEC light will come on befor your oil light, when driving high rev without oil.
Old May 31, 2005 | 09:51 AM
CorradoTJR's Avatar
your problem is that Vtec never worked in the first place...
V-tec....Phhh
i cant believe people still dont know about boost...?
Old May 31, 2005 | 10:36 AM
flood's Avatar
Default Re: Vtec Malfuntion????? P1259 (CorradoTJR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CorradoTJR &raquo;</TD></TR><TR><TD CLASS="quote">your problem is that Vtec never worked in the first place...
V-tec....Phhh
i cant believe people still dont know about boost...?</TD></TR></TABLE>
Trying to act cool eh?
Old Jun 1, 2005 | 11:37 AM
Leviata-N's Avatar
Default Re: Vtec Malfuntion????? P1259 (flood)
Thanks to everybody to try to help, like in all the world always we find persons that only try to jogs about what you are trying to said.
By the way can be the oil level, because it was just a little bit down from the normal level. But any way I will try to find wich wire to use to plug the VTM from the VAFC. If someone knows please tell me the color.
Old Jun 1, 2005 | 12:59 PM
Leviata-N's Avatar
Default Re: (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">
Trying to act cool eh?</TD></TR></TABLE>
Nothing new. Persons like this are around the world
