would a b16 cable transmission work on my 94 b18c motor?
i have a longblock gsr motor from a 94 integra and i want to drop it in a crx, since crx's use cable transmission i wanted to use cable also to keep the swap simple, so i just wanted to know if the b16 cable tranny would work with the 94 gsr motor. thanks people.
Yes.
B-series transmissions -> B-series engines... no exceptions (B-series Prelude exempt)
The transmission you use for your car has to match what the car is setup to use, ie. cable tranny -> CRX, 1st/2nd gen teg, etc., unless you plan to convert the car to otherwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoeG86 »</TD></TR><TR><TD CLASS="quote">would u recommend lsd in there?</TD></TR></TABLE>
^ LSD is not necessary, but it'll depend on how much HP you'll be putting out to the wheels.
I'm not trying to steal your thread but anyone know what axle to use for a cable tranny in a 92 EG? As for the LSD worth every cent in my opinion. Especially if you plan on doing any auto slalom (solo 2)
Thanks
Thanks
