99si or gsr stock springs on my 94 eg?
Old May 30, 2005 | 08:43 PM
d16civicex's Avatar
Default 99si or gsr stock springs on my 94 eg?
any benefit for putting on si springs or gsr springs on my eg. would it lower it at all, im sure not by much. its a different spring rate so would i feel the difference from doing this. thanks for the info
Old May 30, 2005 | 09:04 PM
anngsr's Avatar
Default Re: 99si or gsr stock springs on my 94 eg? (d16civicex)
i put my 97 gsr stock on 94 civic dx, is not that much diff.in height but its a little stiffer on my observation.
Old May 30, 2005 | 11:19 PM
stevenlo's Avatar
unless you have an h22 in your eg then i wouldnt put them on the car. also...
imo
Old May 31, 2005 | 10:33 AM
d16civicex's Avatar
Default Re: (stevenlo)
why only if i have a h22. the si springs are made for a 1.6 liter. its not that much heavier than the 1.6 i have in my eg.
Old May 31, 2005 | 11:18 AM
slammed00si's Avatar
Default Re: (d16civicex)
it may raise your car a little bit. your thinking engine weight when you should be thinking total weight of the car. the si and gsr are both a lot heaveir then your eg. i use itr springs on my eg and it isnt dropped hardly at all with an ls swap. so i imagine yours will sit higher due to the weight off your car. just my .02 c
Old May 31, 2005 | 11:36 AM
d16civicex's Avatar
Default Re: (slammed00si)
sounds right, thanks alot
4doorcivic16
May 11, 2010 11:58 PM
JScott3d
Apr 15, 2009 12:15 PM
Scotty_1988crxsi
Northeast (Sales)
Jan 15, 2009 03:34 PM
wakaranai
Oct 24, 2007 12:09 AM
litterbox
May 11, 2004 05:58 PM
