90-93 teg rear sway bar on 88 dx?
Old Feb 7, 2002 | 06:14 PM
JDM HYBRID's Avatar
Default 90-93 teg rear sway bar on 88 dx?
i know that it will work but will my brackets work?
[Modified by JDM HYBRID, 3:15 AM 2/8/2002]
Old Feb 7, 2002 | 06:34 PM
B16CRX's Avatar
Default Re: 90-93 teg rear sway bar on 88 dx? (JDM HYBRID)
The DX did not come with a rear swaybar stock. Unless you have already put a swaybar in the rear, I don't think you will have brackets.
Old Feb 7, 2002 | 06:40 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: 90-93 teg rear sway bar on 88 dx? (B16CRX)
the brackets are not the problem. you can get those easy.
the problem is that Honda saved 20 cents per CRX by not welding the nuts inside the frame, so when you go to bolt the brackets to the car, the bolts just go right through the hole, no nuts on the other side.
you can drill a hole on the side and fish a nut, or i can sell you two adapter plates
that you bolt to the tow hooks and then installing the sway brakets is just a bolt on deal.
$30 for both brackets, shipped to you
Old Feb 7, 2002 | 07:03 PM
JDM HYBRID's Avatar
Default Re: 90-93 teg rear sway bar on 88 dx? (Spaceballs the lunch box)
SO CAN I USE THE 90-93 TEG MOUNTING poo poo?
importboi22
12
Mar 8, 2004 04:14 AM
BIG RICH
Sep 23, 2003 03:20 PM
rschoener
Mar 19, 2003 10:41 AM
wuhungsixxx
Oct 2, 2001 04:40 PM
Jul 19, 2001 04:37 AM
