B18C5 What would be better the Hondata or Mugen
Old May 30, 2005 | 07:23 PM
hondaleefolife's Avatar
Default B18C5 What would be better the Hondata or Mugen
i just baught my B18C5 and droped it into a 1995 Honda Del Sol. Black on stock rims but painted bronze. i was wonderin next step i will do is either put the hondata ecu or the mugen one. i was wondering which one would be better for my car. after that step i will also be turbo charging the car. along with a few other internal parts at the same time. Just give me some feed back on some openions. anything i need lots of help open to listen to anything. thanx Lee
Old May 30, 2005 | 07:39 PM
jeremy.'s Avatar
Default Re: B18C5 What would be better the Hondata or Mugen (hondaleefolife)
mmmmmmmmmkay...
Old May 30, 2005 | 07:47 PM
mtber's Avatar
A hondata unit is not going to be as cost effective as a chipped ecu programmed for your vehicle. Click here for more information on a chipped obd1 ecu or visit http://phearable.net
Old May 31, 2005 | 02:20 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaleefolife &raquo;</TD></TR><TR><TD CLASS="quote">i just baught my B18C5 and droped it into a 1995 Honda Del Sol. Black on stock rims but painted bronze. i was wonderin next step i will do is either put the hondata ecu or the mugen one. i was wondering which one would be better for my car. after that step i will also be turbo charging the car. along with a few other internal parts at the same time. Just give me some feed back on some openions. anything i need lots of help open to listen to anything. thanx Lee </TD></TR></TABLE>
If your going to turbo your car you need programmable engine management like Hondata. Not a chipped ECU like Mugen.
I have the Mugen N1 ECU on my car right now, and Mugen chipped it with following in mind: You need to have the Mugen I/H/E and you need 11.4:1 compression. If you don't have this, the Mugen ECU is a waste and won't give you more power than stock.
Old May 31, 2005 | 03:16 AM
uNF$@#!'s Avatar
Default Re: B18C5 What would be better the Hondata or Mugen (Pompiuses)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">
stop giving him bad info.
all you need bro is 2 big bottles, a hamster and one of these: https://honda-tech.com/zerosearch
Old May 31, 2005 | 03:40 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaleefolife &raquo;</TD></TR><TR><TD CLASS="quote">after that step i will also be turbo charging the car. </TD></TR></TABLE>
If you're going to continue to be making major changes to the car, one step at a time, then I think you are going to want a Hondata or another fully reprogrammable system.
It'll be more expensive, but if you're going to be making the changes step by step, I think it'll be the more economical choice in the long run.
I don't know a lot about AEM engine management, but I'm sure they sell a computer system that can be reprogrammed as you finish the car.
There also isn't just one kind of Hondata or AEM. I can make do with the cheapest Hondata, but you might not be able to.
I'd suggest you go to the Hondata site and locate a Hondata tuner in your vicinity, make his/her acquaintance, let him/her know excactly what it is you're going to be doing, and then follow his/her suggestions for purchase and tuning.
Old May 31, 2005 | 06:19 AM
Chris N's Avatar
Default Re: B18C5 What would be better the Hondata or Mugen (ekay_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">mmmmmmmmmkay...</TD></TR></TABLE>
JASMA is the way to go.
HatchedGTI
Feb 23, 2006 09:44 PM
Mr.TecH7
17
Feb 24, 2004 09:43 PM
range
Jan 28, 2004 08:00 PM
ZygSpeed
Jan 25, 2004 10:54 AM
$N@kE
May 29, 2003 11:48 AM
