is there a way to tell the diffrence between high and low impedence injectors?
Old May 30, 2005 | 07:11 PM
downeyballz's Avatar
Default is there a way to tell the diffrence between high and low impedence injectors?
a freind of mine has a 91 teg with a gsr swap. the people that did the swap are kinda shady and we dont know what injectors are in the motor the 91 ls which use a resistor box or the newer not resistor gsr ones that came with the motor. the car doesnt feel as fast as it should be when compared with other gsr swapped cars ive been in so im thinking this could have something to do with it. so i was wondering if ther is anyway to tell the diffrence between the two injectors as far a marking on them or maybe voltage at the clips?
Old May 30, 2005 | 07:39 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: is there a way to tell the diffrence between high and low impedence injectors? (downeyballz)
did they re use the ls trans? that would explain y it feels slower
Old May 30, 2005 | 08:08 PM
Default Re: is there a way to tell the diffrence between high and low impedence injectors? (PURPLETERROR)
yeah they used the ls trans becasue it was cable clutch
typeoneeg6's Avatar
test em. u should see about 12 for the obd1's and 2.5-3 ohms for obd0's.
Old May 30, 2005 | 08:10 PM
Default Re: is there a way to tell the diffrence between high and low impedence injectors? (typeoneeg6)
thats the answer i was looking for
snowpro127
Nov 18, 2009 06:57 AM
CivicxTree754
Aug 26, 2008 12:48 PM
JHD_DA
Jun 14, 2005 11:39 AM
downeyballz
Jun 1, 2005 02:47 AM
downeyballz
May 31, 2005 05:46 AM
