Is CRX Dash interchangeable?
I got me an '88 CRX Si but wanted to swap over to the 90-91 dash since it has the smoother looking cluster. Most importantly is that I want to do a Civic Si cluster swap. Do these CRX dashes switch up like OEM beetween the years? If so, then I guess the glove boxes and center console stuff must a little different too right?
Im not sure if they will swap, but i do know you can just swap the cluster shroud. Other than the shroud, are there any differances worth switching for ?
I put a 88 crx si dash in my 91 hb. The wires had be be rewired for the cluster but the dash fits perfect(except for one bolt but its still solid).
yeah all the 88-91 crx even civic dash are interchangeable..it just that the 90-91 uses a different plug on the hazard switch and i think there was one other thing(forgot). you can even use a civic dash in the crx too. ihave done these swap on customer car plenty of time before..and mine own car too.
EFboostedSI
Aug 1, 2009 10:28 AM
Nihilus
Apr 9, 2006 12:49 AM
STHPERFORMANCE
Oct 14, 2003 01:44 PM
