skunk2 intake man. questions on gsr
Old May 30, 2005 | 02:59 PM
4F_ Mugen CoL's Avatar
Default skunk2 intake man. questions on gsr
I have a skunk2 mani. for my '01 motor, i was wondering what stuff i need to get it to work and where to get it. I know obviously to get new gaskets and such, but what about like throttle cables and stuff? I did some searching and didnt find much on what im lookin to find out. can i just bolt up this manifold with new gaskets? do I need other parts? answers would be greatly appreciated. thanks
Old May 30, 2005 | 03:15 PM
notmightydx's Avatar
should bolt right up! get ne gaskets and i am pretty sure you will be set to go. goodluck
Old May 30, 2005 | 04:48 PM
adaml2nv's Avatar
Default Re: (notmightydx)
everything will bolt up just fine, including the throttle cable. but if you want the cleaner look. you can get a ITR cable, bracket and throttle body lever thingy (the round thing thats on the T.B )
also your going to have to "T" off the senser on top of the manifold to another vacume source, such as between the PCV valve and the new manifold.
thanks all
Old May 30, 2005 | 06:40 PM
iH8RICERZ's Avatar
Default Re: (adaml2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adaml2nv &raquo;</TD></TR><TR><TD CLASS="quote">everything will bolt up just fine, including the throttle cable. but if you want the cleaner look. you can get a ITR cable, bracket and throttle body lever thingy (the round thing thats on the T.B )
thanks all </TD></TR></TABLE>
You mean a NON GSR throttle body pulley
ITR throttle cable
ITR throttle cable bracket
p72 GSR intake manifold gasket
OBD 1 Chipped p28 ecu
Old May 30, 2005 | 07:00 PM
adaml2nv's Avatar
Default Re: (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">
ITR throttle cable
lol yeah i my mind went blank when i was typing it up
or he can run a p73 typeR ecu but a obd1 chipped p28 is better
Old May 30, 2005 | 09:50 PM
fergy016's Avatar
https://honda-tech.com/zerothread?id=682550
Old May 31, 2005 | 03:00 AM
Bibnation3's Avatar
for mine, i need to get intake manifold gaskets, throttle body gaskets, type r throttle bracket, type r throttle pulley, and a vacuum
Bibnation3's Avatar
sorry.. Vacuum line
Old May 31, 2005 | 04:53 AM
gen2moredoors's Avatar
INTAKE!!!! everyone forgets this, you'll need a new intake, the gsr one will not fit b/c of the different tb location!
Old May 31, 2005 | 05:54 AM
AllMotorDan's Avatar
yup all you need is a new intake for either the LS or Type R....other than that your IM should just bolt right up and everything from the gsr IM should swap right over.
Old May 31, 2005 | 07:04 AM
neo1z's Avatar
Default Re: (Spoondc4)
Search on this, there are specific things that could make the install significantly easier though. i.e. ITR Throttle Cable etc.
Old Jun 3, 2005 | 12:28 PM
Default Re: (neo1z)
thanks you everyone who replied, i had planned on getting a new intake this week or upcomming week. I was lookin to buy pass. jdm carbon or memoryfab. thanbks for all the help though, greatly appreciated
YangFlavor
Mar 25, 2010 09:55 AM
strongarm1731
Jan 21, 2006 09:04 PM
SSBlueDC2
Aug 3, 2004 10:54 PM
smkngsr
Sep 5, 2002 01:27 AM
lilxvtecxpwr
Aug 2, 2002 05:56 PM
