my turn signals/hazards dont work!!!
Old May 30, 2005 | 02:28 PM
dreams190's Avatar
Default my turn signals/hazards dont work!!!
93 prelude si
ok, neither one of my turn signals work, same with my hazards, i try to turn them on and nothing happens, not even on the gauge cluster... anybody have any sugestions? I've heard it might be the arm on the side of the steering column but the high beams still work when i pull it...
Old May 30, 2005 | 03:02 PM
prelude1897's Avatar
Default Re: my turn signals/hazards dont work!!! (dreams190)
first check your fuses, make sure they're good
Old May 30, 2005 | 03:07 PM
dreams190's Avatar
Default Re: my turn signals/hazards dont work!!! (prelude1897)
done that, for awhile only my left one didnt work at all, now its both of em...
Old May 30, 2005 | 05:43 PM
pr1mo_13's Avatar
not sure on preludes since i don't have mine yet, but on my corolla i had the same thing happen after i messed around behind the dash running rca wires from my cd player and what happened was i forgot to connect the plug to the back of the clock (seperate from the stock tape deck) or the hazard button (can't remember which) check those and if they are connected check to see if any wire got pulled out
Old May 30, 2005 | 05:50 PM
datac99's Avatar
Default Re: (pr1mo_13)
I know you said you checked your fuses... But did you check the fuse block in the driver side foot-well also? I had the exact same thing happen... Had a bulb die on one side, ignored it for a month or two, then everything died - the same as your describing. Ended up being one of the fuses in that panel... Or was it under the hood... Anyway...
Old May 30, 2005 | 06:00 PM
SUB-0 H23's Avatar
Default Re: (datac99)
surprised that no one said to check the flasher...
Old May 30, 2005 | 07:56 PM
PhazedSI's Avatar
Default Re: (SUB-0 H23)
def. the flasher relay
Old May 30, 2005 | 07:58 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUB-0 H23 &raquo;</TD></TR><TR><TD CLASS="quote">surprised that no one said to check the flasher... </TD></TR></TABLE>
Old May 31, 2005 | 10:20 AM
dreams190's Avatar
wheres the flasher relay? and if it were a relay, wouldnt both have gone out at the same time? or are there 2 seperate relays?
Old Jun 3, 2005 | 02:47 PM
dreams190's Avatar
flasher relay? anyone?
Andrew LaRussa
Aug 8, 2015 03:13 PM
chiaxi2002
Jan 5, 2009 08:13 PM
gabe_si
Aug 19, 2008 02:50 PM
bads2k
Jun 25, 2008 09:34 AM
sadangryboi
May 12, 2005 12:10 PM
