how do i know if my clutch is going bad?
hey my clutch seems to be catching really high, does this mean it is going bad? or can i adjust it somehow? if it is going bad how much is it to have someone replace it?
i am assuming catching high means way at the top no travel at all ?? if so it is not an air in system issue , but by the way what year car do you have????
if it has clutch cable it can be adjusted ,up to 89 accords.....if hydraulic it might be time for a new clutch
it should be adjustable. My 92 clutch is adjustable. 94 and up should be the same im not sure but there should be two bolts if u follow the clutch pedal up that should allow u to adjust if its adjustable.
With the clutch in my accord, I havent driven the car for a while, a few miles here or there, nothing too extensive. The thing with my clutch is that its hard to engage and the pedal travels close to the floor in order for me to drop it into gear. I am thinking i want to bleed out the clutch system and i also want to maybe get stainless lines if they offer it, hows that? Any other suggestions?
yo nailos......92 accord is hydraulic thus there is no proper adjustment unless you want to dick around with the pedal height under dash but that is not a proper way to adjust the clutch...if over the years the pedal is really high on a hydraulic system clutch ,,it is about time to put some money aside and start thinking about a clutch replacement
