Which LCA's to use for Comptech sway combo
I have a 96 ek and im sure i cant use my stock lca's because my car did not come stock with a sway bar.
Im getting the comptech rear sway/tie combo and i know im going to need a new pair of lca's.
I know i could always stick with a set of gsr lcas or any other oem lca that came stock with a rear sway but what are my other choices?
I searched and found that SRR lca's work with the comptech combo as well, they seem hard to find and expensive though.
Do omni power LCA's work with comptech rear sway/tie combo?
If not what are some other choices?
Ok so omni power control arms will work with comptech setup, correct if im wrong....
Why do you say look for integra arm first, is that just because its cheeper?
Dude your stock ones do come with swaybar holes. All 96-00 civics have rear lca's that have swaybar holes. Use them, don't waste your money on bling aftermarket ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien »</TD></TR><TR><TD CLASS="quote">Dude your stock ones do come with swaybar holes. All 96-00 civics have rear lca's that have swaybar holes. Use them, don't waste your money on bling aftermarket ones.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dawn Dreaming »</TD></TR><TR><TD CLASS="quote">I have a 96 ek and im sure i cant use my stock lca's because my car did not come stock with a sway bar.
If not what are some other choices?</TD></TR></TABLE>
Buy the SRR purple lcas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Tadashi »</TD></TR><TR><TD CLASS="quote">Integra rear LCA's don't fit on to the 96-00 civic, since there dimentions are diffrent.</TD></TR></TABLE>
i didn't see the 96... sorry.
what ^^ said.
what ^^ said.
Well i can use my stock arms as basically backup, I think I still might get a set of omni power arms b/c it's for a graduation present so i'm not buying them
i just read a post saying that omni power lca's dont come with holes for rear sway bar...? Kind of confused me.
Can someone clearify to make sure omni power lca's do work for comptech rear sway/tie bar combo?
Just go with the oem ones and spend your money somewhere else. You'll be 100 percent sure that they work with the comptech bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dawn Dreaming »</TD></TR><TR><TD CLASS="quote">Well i can use my stock arms as basically backup, I think I still might get a set of omni power arms b/c it's for a graduation present so i'm not buying them
Ask for something that will be of better use.
</TD></TR></TABLE>Ask for something that will be of better use.
god damn it, if i want to waste my money on some non functional LCA's then im ganna waste my money on LCA's
so do omni power lca's work with the comptech bar or not, its like a war to get a simple yes or no answer
Modified by Dawn Dreaming at 8:21 PM 5/31/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dawn Dreaming »</TD></TR><TR><TD CLASS="quote">god damn it, if i want to waste my money on some non functional LCA's then im ganna waste my money on LCA's
Modified by Dawn Dreaming at 8:21 PM 5/31/2005</TD></TR></TABLE>
Go see if the OMNI power lca's have the holes for swaybar mount on them.
That will answer your question.
Why the **** are these aftermarket LCAs selling so well? It's pretty obvious that they are not up to the quality of the OEM units. Why the hell would you want shitty bushings that are held in place by set screws. Good luck with all that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dawn Dreaming »</TD></TR><TR><TD CLASS="quote">hey thanks for your comment, it really helped
Sorry, that's just the way I feel. Didn't mean to rant...
</TD></TR></TABLE>Sorry, that's just the way I feel. Didn't mean to rant...
EL-Driver
Jul 29, 2004 06:53 PM
MintyDip
Jun 27, 2002 05:27 AM
