rimsvs. alignment *searched
just 2 fast questions
first, will changing the rim size (17) affect alignment at all? my set up is aerospeed coilovers with kyb agx's....and its dropped about .8-1 inch - tire size will be 205/40/17
second...
do i need aftermarket lug nuts for my rims? or will the stock ones work fine? (95 civic) the only reason i ask is someone told me i NEED them... true or false?
thanks
second...
thanks
alignment should be fine. but you should get it done anyway if you havent already since changing your springs.
you need aftermarket lugnuts. OE lugnuts are different and dont match.
seanno
Jan 28, 2007 03:57 PM
