Swap options
Old May 30, 2005 | 10:59 AM
Blueallie's Avatar
Default Swap options
My old lady's car is a 95 v-6 accord 4 dr. The engine is smoking pretty bad and she wants a new engine. Will a j30 from the newer accords swap in. I tried to talk her into an h22 swap but that just inst feasible. Any ideas? Oh the car is an automatic and needs to stay that way.
Old May 30, 2005 | 11:38 AM
Confuc1ous's Avatar
I wonder if you can throw in an automatic H22. Although not as fast as a manual, it will still be peppy and probably faster than the 175hp v6 you have at the moment. I suggest you contact one of these places that sells motors, they might be able to give you an idea of what you might be able to swap in.
Old May 30, 2005 | 12:01 PM
philadd's Avatar
Default Re: Swap options (Blueallie)
The j30 isn't really a feasible solution. Everything would need to be fabricated to get it into the engine bay, and that's IF it would even fit, which I'm pretty sure it doesn't. Since you said an h22 isn't feasible either, your only real choice is just to replace the motor with another c27.
Old May 30, 2005 | 12:03 PM
Confuc1ous's Avatar
if its not feasible because of budget, well an auto H22 is cheaper. Just threw it out there if that changes anything for you.
Old May 30, 2005 | 04:13 PM
Blueallie's Avatar
Default Re: (Confuc1ous)
How hard of a swap is it? Will i have to buy mounts and all that stuff.
Old May 30, 2005 | 07:01 PM
philadd's Avatar
Default Re: (Blueallie)
yes, you would need mounts... going from the c27 to an h22 is not easy. to be honest, i'm not sure just how much work it would take, if the subframe is different, if it's really even worth trying, etc.
Old May 31, 2005 | 01:43 PM
Blueallie's Avatar
Default Re: (philadd)
How about the older legend engines. they are stamped c27. You think that would work?
Old May 31, 2005 | 02:26 PM
philadd's Avatar
I think you probably could, but I can't give you a positive answer. Personally, I would stick with the c27 from the Accord. The c27 from the Legend (1st gen) were rated at 160 hp and 162 tq, while the Accord's c27 is 170 hp and 165 tq. Not to mention, the Accord's c27 will probably be easier to find, and with less miles.
baker1218
May 14, 2011 12:56 PM
1BADEGDC2
Apr 6, 2009 04:42 AM
Dagrasser12
Jul 22, 2004 02:29 PM
Nick0158
May 22, 2003 08:53 AM
