mini me setup....will my budget build be fast enough to run 14's? inputs appreciated.
Old May 30, 2005 | 10:28 AM
TrackSpeedRacing's Avatar
Default mini me setup....will my budget build be fast enough to run 14's? inputs appreciated.
-1990 CRX Si D16A6 stock bottom end (120,000 miles)
-1998 Ported and Polished, 3 angle valve job D16Y8 complete cylinder head assembly.
-D16Y8 head gasket
-1998 GSR B18C1 bored out throttle body (64mm)
-Match ported intake manifold
-Blox Racing Stage 2 Camshaft
-1990 CRX Si transmission
-act 6 puck clutch with lightweight flywheel
-3 inch cold air intake system
-megan racing 4-2-1 stainless steel header
-rc engineering 310cc injectors
-zdyne ecu
-aem cam gear
-b&m fuel pressure regulator
-2.25 inch test pipe w/ thermal r&d catback exhaust system
All this will be in a 1989 Honda CRX DX model with full interior. What do you guys think of this setup? Good enough for 14's? Any and all suggestions are welcomed. Thanks!
Old May 30, 2005 | 10:32 AM
Suck my DX's Avatar
Default Re: mini me setup....will my budget build be fast enough to run 14's? inputs appreciated. (1320JDMGS
with proper driving technique u will be in the 14's for sure...u got dyno numbers?
Old May 30, 2005 | 10:52 AM
StupidSlowRSX's Avatar
Thats a nasty little single cam setup. Espicially tuned with Zdyne.. You should see low 14's with some bigger injectors easy.
Old May 30, 2005 | 10:55 AM
Suck my DX's Avatar
but still...why didnt u just swap...with as much or less money than u put in to your SOHC u could have been way faster with any B
Old May 30, 2005 | 11:05 AM
oh thats because I have more than half of the parts I need just sitting here in my garage.
Old May 30, 2005 | 11:07 AM
Suck my DX's Avatar
oh...lol...that would make sense then
Old May 30, 2005 | 11:45 AM
SpecialEdxl's Avatar
go for it player
Old May 30, 2005 | 11:51 AM
Burlyirishdude's Avatar
Default Re: (SpecialEdxl)
sounds pretty sexy.....you would deffinately show my HF a good time.
Old May 30, 2005 | 06:55 PM
Default Re: (Burlyirishdude)
forgot to mention:
jimfab traction bar
20x8x14 mickey thompson slicks on 14 inch steelies.
h&r race springs/stock shocks
what else do you guys recommend?
Old May 30, 2005 | 06:58 PM
ecovillain's Avatar
Default Re: (1320JDMGSR)
14s fo sho.
Old May 30, 2005 | 09:01 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320JDMGSR &raquo;</TD></TR><TR><TD CLASS="quote">forgot to mention:
jimfab traction bar
what else do you guys recommend?</TD></TR></TABLE>
DAMN YOU...i NEED traction bars and slicks..lol...:wish there was a shaking fist icon:
Old May 30, 2005 | 09:35 PM
Default Re: (AMPYR_one)
I know this might be a little off and out there.....
But as far as your Reving goes......I was thinking....
New retainers and valve springs....on the valves... If you increase the RPM allowance....does that straighten out your power band? &lt;---trying to get more technical with my own knowledge....so i'm just asking.
So....increase the RPM limit by adding stronger/lighter....retainers/springs on the valvetrain= straighter power band= better times for the drag?
Is that right? Just wondering.....I saw all the work you had planned to do with the valvetrain and wondered if the stuff i just mentioned was thought of....again.....can't wait for pics.....
Modified by Burlyirishdude at 10:46 PM 5/30/2005
Old May 30, 2005 | 11:46 PM
92integra_gs's Avatar
full interior? bro you got to lose some wt. then you will see 14s and try running on some slicks
almostboostedgsr
Mar 24, 2008 07:47 AM
majinx4
12
May 8, 2006 04:58 AM
MadModder
Oct 10, 2005 06:55 PM
Wasabithegosu
35
May 17, 2005 12:40 PM
AgentJam
45
Sep 19, 2003 09:08 AM
