p28 or p75 for ls motor
Old May 30, 2005 | 10:23 AM
STPREZ's Avatar
Default p28 or p75 for ls motor
i have 94 ls motor in my 92 dx hatch
i have been using the stock ls p75 ecu but im starting 2 see problems after a 8 months ago after electronics teacher installed skunk 2 chip off ebay that fucked somthin up: lemp home mode at 3000rpm an ac stayed on
i got the chip removed a day later an i had 2 put a switch on my ac and since then ive never payed much attention til after the swap from my totaled 94 ls to 92 dx hatch and i upgraded 2 a 2.5in full exhaust- it back fires when i change gears an when im take my foot off the gas around 5grand
it did this in my teg after the chip was put in aswell i just notice it more n the hatch cause of different exhaust
i heard stock ls ecu goes 2 bout 7000-7200rpm an my untuned safcII says 6900 at the red line
im tryin 2 get a new ecu an i know p28 is vtec but i can still use it just wit a check engine light
will it really hirt anything on the motor an what is the redline on p28
Old May 30, 2005 | 10:40 AM
Kendall's Avatar
Not only is the P28 a VTEC ECU (which will throw two codes), the fuel and ignition maps aren't correct for an LS motor and will cause it to run like utter ****.
Regarding the LS redline, stock Integra tachs are usually inaccurate and read a few hundred rpm's on the high side. Stock redline is closer to 6900.
Old May 30, 2005 | 07:35 PM
mtber's Avatar
Default Re: (Kendall)
As I replied in the "tech" area.
You can chip a obd1 p28 ecu with a non-vtec p75 program, then if you ever decide to go vtec, all you need to do is drop in a vtec programmed eprom chip
Old May 31, 2005 | 05:32 AM
LSBOI's Avatar
Default Re: p28 or p75 for ls motor (STPREZ)
yo i am loscated in the beach if you need a p75 i have one give me a hit and its yours also have a pr4 if anyone needs it
slob20ef
Mar 29, 2009 05:54 PM
JDMstatus95
Mar 2, 2007 10:24 PM
STPREZ
May 30, 2005 03:10 PM
Vtec92Civic
Oct 3, 2004 02:58 PM
