what full coil system for under $1k?
Old May 30, 2005 | 08:12 AM
jdm phantomx's Avatar
Default what full coil system for under $1k?
im alittle bit torn between the coil system...which im looking to purchase real soon. i really dont see the difference between tein ss and tein ss pro. the d2 rs is comparable to tein flex and so is the megan racing with its 32 way adjustable. omnipowers are real good but are not adjustable. or should i just go out and buy tein flex by forking over a few more hundred...please tell me your experience...my setup will be mostly for street use..and once in awhile probably good spirited driving at the tracks
Old May 30, 2005 | 08:20 AM
Kendall's Avatar
It takes quite a bit of skill to outdrive what the Omnipower's are capable of, and for the price, you can start to invest your money elsewhere, perhaps a rear sway bar upgrade.
Old May 30, 2005 | 10:43 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: (Kendall)
i dont see why it would cost 1000 for a full coil system. im just going to buy tokico struts with tein lowering springs; that will be sufficient for me. im going to get some cheap strut bars and thats as far as my suspension mods will go.
Old May 30, 2005 | 10:59 AM
riceball777's Avatar
Default Re: what full coil system for under $1k? (broken sword)
i would get the tein ss
i wouldent get the omni cuz they are not adjustable
Old May 30, 2005 | 11:00 AM
vtechphone's Avatar
i would say find a set of koni's they are the best ive ridden on
Old May 30, 2005 | 11:04 AM
Kendall's Avatar
Default Re: (benb18a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a &raquo;</TD></TR><TR><TD CLASS="quote">i dont see why it would cost 1000 for a full coil system.</TD></TR></TABLE>
Most coilovers are designed to work better as a single unit than are generic shock/spring combinations. Many of them also come with the more stable pillow ball upper mounts as well. Once in a while you run across a shock spring combination that works particularly good, but it's easier and often more effective to buy coilovers.
Old May 31, 2005 | 07:29 AM
dc2legend's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
Most coilovers are designed to work better as a single unit than are generic shock/spring combinations. Many of them also come with the more stable pillow ball upper mounts as well. Once in a while you run across a shock spring combination that works particularly good, but it's easier and often more effective to buy coilovers.</TD></TR></TABLE>
And yet there are those that would argue this point to their death....
Old May 31, 2005 | 07:48 AM
Dc2 Powered's Avatar
i'd get some GC Coil + Koni Yellows
Civic Si Kid
18
Jul 26, 2004 08:20 PM
brian2903
Jun 16, 2004 05:43 AM
TeGgY-gS-r
Apr 22, 2004 06:09 PM
B18B1DOHC
Nov 30, 2003 08:54 PM
MeanGreenEG9
Apr 25, 2003 05:34 PM
