Suspension & Brakes Theory, alignment, spring rates....
Suspension pics
Old May 30, 2005 | 06:33 AM
Corruption's Avatar
Default Suspension pics
Hey guys, I already tried posting this in the Accord forum, but with no luck. I just wanted to make sure I have everything with the KONI fronts and back....the part #'s are 8041-1257Sport for the front and 80141-1258Sport for the rear, this is for an 01 Accord LX coupe, here they are -
Front shocks & Hardware -
Rear shocks & Hardware -
Rear Hardware -
Crappy pic -
Old May 30, 2005 | 07:19 AM
CRX Lee's Avatar
Default Re: Suspension pics (Corruption)
It looks like you have the right parts. Each shock has two jam nuts, one steel sleeve, one cupped washer (faces up when installed), two flat washers of slightly different OD, and a white plastic bump plate that can be either a cup or a disc and sits on the top of the shock itself.
If the car is going to sit on the stock springs, my vote would be to use the lower spring perch locations and knock about 20 mm or so off the ride height but that is my own preference. If you are using lowering springs, keep the perche clips in the stock location.
Old May 30, 2005 | 09:39 AM
Corruption's Avatar
Nope, I've gone through the money and effort to do it all right. My Ground Control Coilovers are due in by next thursday...
Old May 30, 2005 | 07:39 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (Corruption)
Why didn't you just wait a week? No point in doing twice the work, IMO.
Old May 31, 2005 | 06:00 AM
Corruption's Avatar
what exactly are you talking about?
Old May 31, 2005 | 04:19 PM
Corruption's Avatar
Are there any special instructions I will need to give the shop to install the konis and gc coilovers?
Old May 31, 2005 | 04:26 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
oh. i thought you were showing the pics after you installed the konis.
why are you paying a shop? it's a simple job.
Old May 31, 2005 | 04:46 PM
Corruption's Avatar
because I'm retarded, i dont want to get a spring compressor, and I don't trust myself.....im trying to find a reputable shop around here who has experince but I havne't had the best luck, I live in Holland, NJ and I live about 45 west of newark airport...trying to find something within a 10 mile radius of me
Old May 31, 2005 | 05:00 PM
haveaniceday's Avatar
really i thought i wouldnt be able to do it .. after a failed attempt.. but read up on some installs .. just take your time to make sure you do it right the first.. ithink a shop would charge more than 200.. i would spend a few nights researching installs.. thats what i did and im so glad i did the install myself
Old May 31, 2005 | 07:52 PM
Cerberus2k7's Avatar
And the knowlege you gain from doing the install will make you want to work on your honda some more. :D and the $200 you save from having a shop do it can go to an air intake or something else to help the car.
Old May 31, 2005 | 08:57 PM
green-'s Avatar
Default Re: (Cerberus2k7)
Yes it's a very simple install.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cerberus2k7 &raquo;</TD></TR><TR><TD CLASS="quote">And the knowlege you gain from doing the install will make you want to work on your honda some more. :D and the $200 you save from having a shop do it can go to an air intake or something else to help the car.</TD></TR></TABLE>
I would hope you wouldn't spend $200 on an intake
Old Jun 1, 2005 | 09:38 AM
Corruption's Avatar
I rather it get done right rather than me get frustrated since I have short patience and tolerance when problems arise, $300 is worth less to me than the head ache which will probably be created....
deagleEF8
Oct 27, 2011 02:44 AM
Corruption
May 30, 2005 11:05 PM
mv10s
Apr 5, 2004 08:58 AM
Scotty_8_9@yahoo.com
Aug 23, 2001 10:10 PM
