JDM ZC SOHC Non-Vtec cam specs
Old May 30, 2005 | 04:56 AM
rice is nice's Avatar
Default JDM ZC SOHC Non-Vtec cam specs
Good turbo cam?
Modified by jonny-cakes at 11:44 AM 12/22/2005
Old May 30, 2005 | 09:54 AM
Tyson's Avatar
Default Re: JDM ZC SOHC Non-Vtec cam specs (Killa-X)
http://effinmotorworks.com/SOH...s.htm
so far as i can tell with the known information, both the "SOHC ZC" and "mystery" cam are indeed SOHC ZC cams. there are just different SOHC ZC engines (carb and PGMFI), so its hard to tell what youre getting.
:edit: actually it is easy to tell. if it has a huge extra lobe at the distributor end, then its a carbed cam. if its not there, and its from a SOHC ZC, then its MPFI.
although that page will claim their "sohc ZC" cam is the PGMFI cam, i believe their "Mystery cam" is really the PGMFI cam. and probably what youll be getting from that ebay guy.
one thing for sure tho is that any cam claiming to be a SOHC ZC cam is certainly NOT THE SAME as a d16a6 cam.
Modified by Tyson at 2:38 PM 5/30/2005
Old May 30, 2005 | 11:41 AM
FalkenSiR's Avatar
Many people will tell you different things. But the thing is, the only true difference between these engines is the cam. Honda has always made different cams for different engines based on their purpose. The D15B1 cam is a fuel efficient cam and is different than the D15B2 cam. The D16A6 is the best usdm -91 cam, period. The power difference is in the pm7 ecu + cam
Old May 30, 2005 | 01:23 PM
Tyson's Avatar
Default Re: JDM ZC SOHC Non-Vtec cam specs (fast88std)
i just figured out that the specs labelled "sohc zc" is from a carbed engine (105ps). the "mystery ZC" cam is from the SOHC ZC MPFI engine (120ps).
at this point, im 100% certain.
you can see the intake timing is the same, just higher lift. .233 apparently this is where the extra 10hp is from...
Old May 30, 2005 | 10:38 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
you can see the intake timing is the same, just higher lift. .233 apparently this is where the extra 10hp is from...</TD></TR></TABLE>
+ PM7 ECU.
Otherwise obd0 sohc engines would be equipped with PM6s from factory.
Old May 30, 2005 | 10:41 PM
Tyson's Avatar
hmmm yeah but did they use PM7 for SOHC JDM ZC Integras??
Old May 30, 2005 | 10:51 PM
FalkenSiR's Avatar
Default Re: JDM ZC SOHC Non-Vtec cam specs (Tyson)
I think all the intregras came with the DOHC version- PG7.
Old May 30, 2005 | 10:56 PM
Tyson's Avatar
uh. no. the SOHC came from the base model integras in japan. go to page 2, dave lists al the sources of ZC engines.
https://honda-tech.com/zero...age=2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">I think all the intregras came with the DOHC version.</TD></TR></TABLE>
SOHC ZC's arent from civic or CRX.
but it brings up an intersting question. what ecu did they use for these SOHC ZC's?
Modified by Tyson at 12:08 AM 5/31/2005
Old May 31, 2005 | 05:24 AM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">what ecu did they use for these SOHC ZC's?</TD></TR></TABLE>
I've read the PR5 is for the sohc zc teg.
The 88-89 PG7 will work on a sohc zc but its not ideal. Neither is a PM7 or PR4.
I would think that a stock 90-91 PM6 with an adj fuel pressure regulator set 2lbs higher and the ignition timing advanced a couple degrees would ideal engine management for the sohc zc.
Old May 31, 2005 | 09:12 AM
Tyson's Avatar
Default Re: JDM ZC SOHC Non-Vtec cam specs (davens)
thanks for the tip. according to pgmfi.org they believe PR5 is it also.
PR5 : 90-91 JDM Integra ZXi (1.6 sohc)
89D15CRXDX
Oct 22, 2006 02:23 PM
mattie_96
Apr 2, 2006 01:22 PM
Ahknodd
Jun 9, 2005 04:43 PM
davens
Feb 6, 2004 07:21 AM
