Rear Bumper ' filler ' piece removal (91 hatch)
Old May 30, 2005 | 04:42 AM
from_zer0's Avatar
Default Rear Bumper ' filler ' piece removal (91 hatch)
I'm looking to replace the filler piece between the actual rear bumper and where the taillights are on a 91 hatch. Was rear ended and tweaked the bumper a bit, making a very small gap just above and behind the rear wheel wells, but the most unsightly part is this filler piece which is tweaked into a constant 'snarl' (Think of the taillights as eyes and only the left side of this piece bent up in an elvis-style lip curl)
I'm thinking i may just be able to change out this filler piece and have it looking more or less good as new ( as 'new' as a 15 yr old car can look ) But may have to change the bumper as well.
My manuals suck *** when it comes to this, so if someone could enlighten me on getting this filler piece removed/reinstalled, and/or perhaps the whole rear bumper, it would be much appreciated.
I just want my car's '***' to look hot again and not mangled!
from_zer0
PS Happy Memorial Day to all! BBQ & B33R!
Old May 30, 2005 | 07:17 AM
Wes V's Avatar
Default Re: Rear Bumper ' filler ' piece removal (from_zer0)
There are two bolts and two nuts that have to be removed. You do not have to remove the hatch release lock!
Remove the rear bumper. The two bolts are at each end. The nuts are toward the center and are about 2 feet apart (one foot from the car centerline).
You do NOT have to remove any of the interior panels to get to any of the nuts or bolts.
That's all it is.
Wes
Old May 30, 2005 | 11:56 AM
Zaakro's Avatar
Default Re: Rear Bumper ' filler ' piece removal (Wes V)
yeah I did that yesterday cuz i got the JDM filler piece for my rear bumper. you have to unbolt 4 nuts to get the bumper off 2 are on the inside of the car under the tail lights on the left and right side and the other 2 are under the car. then after you pull the bumper off you have to unbolt 2 bolts and 2 nuts from the underside of the filler piece.... good luck it takes a few minutes if you can find all the bolts
Old May 30, 2005 | 11:58 AM
JapJunkie's Avatar
Default Re: Rear Bumper ' filler ' piece removal (Zaakro)
Signed on just in time.
I just bought a US rear filler piece and was wondering..
Are all U.S. 88-91 HB filler pieces the same??? No diff. between 88-89 and 90-91.
Modified by JapJunkie at 1:12 PM 5/30/2005
Old May 30, 2005 | 12:11 PM
Zaakro's Avatar
Default Re: Rear Bumper ' filler ' piece removal (JapJunkie)
i have a 88 hatch and i know with the JDM one i have that is from a 90 there is a differents. the key hole is about 3-4 inches to the right on the 90, now i dont know if its the same in the US or not
Old May 30, 2005 | 12:37 PM
JapJunkie's Avatar
I think the junkyard gave me the rear filler off of a 90-91, im hoping this b/c I have a 89. When i went to install it, the keyhole lines up, but sits deep inside the filler, its not flush.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by from_zer0 &raquo;</TD></TR><TR><TD CLASS="quote">
ohh ya and werd, exactly wat im up 2.
Old May 30, 2005 | 02:02 PM
JapJunkie's Avatar
ttt
Old May 30, 2005 | 02:25 PM
Losrocket_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">yeah I did that yesterday cuz i got the JDM filler piece for my rear bumper.</TD></TR></TABLE>
Whats the difference between the JDM rear filler and the USDM one?
Old May 30, 2005 | 11:09 PM
Zaakro's Avatar
Default Re: Rear Bumper ' filler ' piece removal (Losrocket_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Losrocket_ &raquo;</TD></TR><TR><TD CLASS="quote">
Whats the difference between the JDM rear filler and the USDM one? </TD></TR></TABLE>
it sticks out about an inch more than the USDM, I will take a pic tomorrow
Old May 31, 2005 | 09:22 AM
JapJunkie's Avatar
Are all U.S. 88-91 HB filler pieces the same??? No diff. between 88-89 and 90-91?
Modified by JapJunkie at 11:50 PM 5/31/2005
Old May 31, 2005 | 10:51 PM
JapJunkie's Avatar
TTT
Old May 31, 2005 | 11:44 PM
Zaakro's Avatar
if you need the 88 filler piece i could give you mine and if its for the pudding car its already painted
Old Jun 2, 2005 | 08:57 AM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">if you need the 88 filler piece i could give you mine and if its for the pudding car its already painted </TD></TR></TABLE>
Nah dont have it anymore, sold.
I just need to know if all USDM 88-91 rear fillers the same?
Old Jun 5, 2005 | 09:31 AM
from_zer0's Avatar
Thanx to all for the replies...sorry i can't be of any help on the jdm vs. usdm fitment issue.
Have had some online issues so access is sporadic...will probably yank it this weekend.
Cheers!
from_zer0
Old Jun 9, 2005 | 02:57 AM
JapJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie &raquo;</TD></TR><TR><TD CLASS="quote">
I just need to know if all USDM 88-91 rear fillers the same?</TD></TR></TABLE>
Tried searhing...
Niftythang
May 25, 2011 06:41 AM
VTECth1s
Paint and Body
May 18, 2007 12:55 PM
usdmEHboy
Jan 6, 2006 04:30 PM
Stunna MIKE
Nov 13, 2005 03:58 PM
4ghatch
Jun 10, 2003 06:09 PM
