Swapping out an old steering wheel for a NEW one??? How hard is it?
Old May 29, 2005 | 09:27 PM
Hatch It's Avatar
Default Swapping out an old steering wheel for a NEW one??? How hard is it?
My girlfriend just got an integra, and the steerign wheel was pretty nasty
So i got her a new one, im just wondering how hard it is to replace it and what tools are needed?
Are there any other posts that go over it? I searched but im not familiar with integras at all...
please help
Old May 29, 2005 | 10:02 PM
SYTFU Tommy.'s Avatar
Default Re: Swapping out an old steering wheel for a NEW one??? How hard is it? (Hatch It)
not ahrd, hard finding the airbag key though since the botls for the airbag isnt a normal bolt.
Old May 29, 2005 | 10:12 PM
Haleiwa-Brando's Avatar
Default Re: Swapping out an old steering wheel for a NEW one??? How hard is it? (tngay)
This is pretty easy. I suggest getting a manual. Main thing is you need a little 8-sided star looking allen head screw driver to loosen the four bolts on the side and underneath the steering wheel. This is to remove the airbag. Make sure you disconnect the battery first and when removing the airbag make sure your face isn't in the way. After you remove the airbag you need a 17mm socket with a short extension and a wrench. Loosten counter clockwise. Before you slide the steering wheel off, look at the splines on the male end of the steering wheel shaft. There should be a little dash of yellow paint indicated by the factory on where the steering wheel lines up to be level. Slide the old one off and the new one on, do everything in opposite order. Done.
Old May 29, 2005 | 10:24 PM
sinister357's Avatar
Default Re: Swapping out an old steering wheel for a NEW one??? How hard is it? (Haleiwa-Brando)
if my memory serves me right, that "star" driver in something like a t25 or t35. and that nut holding the wheel might be a 19mm.
Old May 30, 2005 | 01:00 AM
aeon's Avatar
it's really simple. just need the right size tools. i swaps my brothers out just last night and it took me like 5-10 minutes. prolly because i've done it once before, but it's really easy.
Old Jun 3, 2005 | 10:56 AM
Default Re: (aeon)
correction. that star driver is a t30. my bad
With Tha Flow
Honda Civic (2001 - 2005)
Aug 24, 2018 06:35 AM
thebluecrx
Dec 26, 2010 02:44 PM
DC5mike
Jan 12, 2008 08:15 PM
b18_crx
Jun 19, 2006 09:19 AM
hanskies
May 24, 2006 03:34 PM
