ITR Gauge Cluster wiring
Old May 29, 2005 | 08:50 PM
Zatzy's Avatar
Default ITR Gauge Cluster wiring
I just got myself a ITR Gauge cluster and i need to wire it into my 89 CRX DX. Now i heard that these clusters are plug and play with integras....how true is this? because if so then i will just pick up an integra manual so that i know what wire goes were....now if they are not or the color of the wires are different then my question is were can i get a manual or maybe a site with the wiring diagram for the integra type-r cluster....thanx in advance for any help.
Old May 29, 2005 | 08:53 PM
crxh22project's Avatar
Default Re: ITR Gauge Cluster wiring (Zatzy)
i was just searching this earlier and i found this
http://www.angelfire.com/dc/oregonimport/gsr.html
though i would like to know more but all those topics are like from 02.
you are going to need an electronic VSS
Old May 29, 2005 | 09:07 PM
Zatzy's Avatar
Default Re: ITR Gauge Cluster wiring (crxh22project)
yeah i already have the electronic vss....that no problem wiring up....3 wires.
as for that site...i have been there. if i can use that site then great....this would be my question then about it....how different are the 88-89 from the 90-91 wiring? casue if they are the exact same colors and everthing then that site will work for me
Old May 29, 2005 | 09:29 PM
Zatzy's Avatar
ok well i just was on that site...and i matched up there wiring to my itr cluster and they are not the same.....so i am going to type them out and if anyone knows where i can get the correct info that would just be awsome
Plug B
b1 - red/blue
b2 - green/red
b3 - yellow
b4 - blue/white
b5 - not used
b6 - blue/white
b7 - green
b8 - blue/red
b9 - black
b10 - red/black
b11 - black/yellow
b12 - not used
b13 - green/blue
b14 - red/green
b15 - green/yellow
b16 - red/green
b17 - green/red
Plug C
c1 - not used
c2 - not used
c3 - not used
c4 - yellow
c5 - not used
c6 - black
c7 - yellow/green
c8 - not used
c9 - white/blue
c10 - red
c11 - yellow/red
c12 - green/orange
c13 - blue
so i am hoping with that info someone could have the answers for me....i was hoping that site would help but the wires dont match up to what they say......so any help would be so greatly appreciated thanx
Old May 29, 2005 | 11:15 PM
PURPLETERROR aka BIGMATT's Avatar
Search my friend
Old May 30, 2005 | 07:17 AM
Zatzy's Avatar
Default Re: ITR Gauge Cluster wiring (PURPLETERROR)
well thank you....and i did search. though the charts that i found did not match up to mine. kinda why im asking....
Old May 30, 2005 | 11:39 AM
i searched too and all didn't find anything, the only thing you see in every dam post "Search"
Old May 30, 2005 | 01:31 PM
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
Its pretty simple to trace the wiring from the back of the itr cluster to the appropriate pin. It tok me 2-3 hours to completely wire my gsr cluster including the vss and mounting the hood
http://www.ef-honda.com/ben/DCcluster.php
use the colors/pins from this site for the wiring in your car
http://www.ef-honda.com/main/viewtopic.php?t=10249
this has some good pics and pinouts for the 88/89 harness
Good luck, and remember, search is your friend, this took me about 10 minutes to find
Modified by PURPLETERROR at 10:45 PM 5/30/2005
Old May 30, 2005 | 03:29 PM
i have a b16 can still use any civic or integra vss?
Old May 30, 2005 | 03:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22project &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16 can still use any civic or integra vss?</TD></TR></TABLE>
Yes, i used a 92-95 sohc civic si vss and it worked fine, spedo reads perfect
Old May 30, 2005 | 05:18 PM
Zatzy's Avatar
but that list that you just gave me does not match up at all with mine. I know that the GSR cluster is different then the type-r and im trying to find the type-r wiring.
Old May 30, 2005 | 05:51 PM
that was for type r wiring, are you sure you got the right plugs with your cluster, it realy dosent matter, trace the wirer on the back of your cluster, its really very easy, Fyi the 13 pin plug is exactly the same, and the other plug is a 16, not 17 pin plug, and almost every wire is the same just reverse your order, or mine.
Modified by PURPLETERROR at 3:05 AM 5/31/2005
Old May 30, 2005 | 06:27 PM
Zatzy's Avatar
i am hoping that i got the right plugs. ill try tracing them...thanx
Old May 30, 2005 | 06:35 PM
Zatzy's Avatar
i was reading the wires in the wrong direction.....they are all the same except two.
one is the orange wire which you say vss.....but they can be diff color right? cause mine is blue/white
the other is on the right plug....number 8 you said its red-power....mine is a black wire? so any ideas on that one?
but thanx for all the info
Old May 30, 2005 | 07:01 PM
no prob, just trace the wires on thr back of your itr cluster to be sure, glad i could help ya
Old May 31, 2005 | 05:10 PM
Zatzy's Avatar
i traced them and that wire leads to one side of 3 of the lights. the other side runs back to pin 7 which you said was red/black-power....
7. red/blk power
8. red power (so are you sure this is not blk-ground?)
i guess it would have to be if the other side of the light bulbs is the red/blk-power correct?
Old May 31, 2005 | 05:24 PM
try and post a detailed pick of the front and back of your cluster
Old May 31, 2005 | 07:57 PM
kid-crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">try and post a detailed pick of the front and back of your cluster</TD></TR></TABLE>
that would be helpful and i want to see what this looks like ne ways
Old May 31, 2005 | 08:55 PM
Kryogen's Avatar
hope this helps you.
http://www.thezcr.com/forums/s...+swap
The pictures represent factory Wires location.
The 95+ teg are what therye pins are put 2 & 2 together and you can get it into your car.
Old May 31, 2005 | 09:22 PM
FaceTuned's Avatar
dont meen to jack the post, but how'd you get a 92-5 VSS to fit on the 88-91 without the rear motor mount hitt'n the electric vss ?
Old May 31, 2005 | 10:44 PM
Zatzy's Avatar
Default Re: (jdmhatchness)
well i hope this pic works for you. if not then just tell me and ill take another. the one should be pretty big so that its easy to fallow
Old Jun 2, 2005 | 02:17 AM
Zatzy's Avatar
Default Re: (Zatzy)
bump
Old Jun 2, 2005 | 02:28 AM
Kilburn's Avatar
Default Re: (Zatzy)
im guessing you didnt get the wires from the cluster when you bought it?
Old Jun 3, 2005 | 07:23 AM
Zatzy's Avatar
Default Re: (Kilburn)
no they did come with the cluster when i bought it. all the wires that PURPLETERROR said did match up to mine accept that he said that #8 on the left pin should be a red wire possitive accept mine is a black wire..... The pin that i need to know about is in the picture. its the left clip slot without the clip in it, its the pin that is on the right side of the clip release. or you can count 9 pins in from the left of the pic. so if anyone could trace that and give me an answer if it is (+) or (-) that would be great. I was told that the 10th pin from the left is also positive and i believe that the 9th pin hits on side of the bulbs in the cluster and the 10th pin is on the other side....so i assume one should be negative and one should be positive unless im wrong. any help would be great cause thats the only wire im lost on.
Old Jun 3, 2005 | 08:24 AM
APEX CRX's Avatar
bump for good info
