Another car won't start question/problem
Old May 29, 2005 | 08:45 PM
C uR eX's Avatar
Modified by C uR eX at 2:12 AM 5/5/2006
Old May 29, 2005 | 09:31 PM
deserthonda's Avatar
wow you have replaced a lot of stuff ,,so you are not getting spark ....was the reason you replaced all this because car was not starting?? could you give me a bit of background? did car die on you while driving??
have you checked t-belt make sure it is ok? chk cam timing? any codes?? if you got no spark dont waste ur time trying to jump start car it still wont start,,,all plugs at dizzy are properly plugged in? if you replaced ignitor did you make sure to reconnect all the wires properly i have seen that happen people connect ignitor wires to wrong place
Old May 29, 2005 | 09:52 PM
Davidxx's Avatar
Default Re: (C uR eX)
C uR eX,
I recently have a similar issue with my old 87 LXi, 4door, Fuel Injection (still good condition though) and I went through all these stuff and replaced a whole bunch of stuff just like you did i.e. caps, cap's rotor, main relay, spark plugs, spark's wires, and some fuses due to the fact that my car won't start. Meaning, I can hear the "cranking up, but it won't start up at all." Anyways, in the end, I found out that it was my "ECU", and so I went out to a Junk Yard and was able to find an ECU for my car. Now it's back in bussiness and running like normal. Hey....it won't hurt to go to a Junk Yard and find one for your car. My ECU only cost me like $16 and I'm pretty happy with it. I'm not an "expert" on cars, but at least that solved my problem.
Old May 29, 2005 | 11:10 PM
Robot Sonic's Avatar
do you know what the problem with the old ECU was? why was it giving you problems?
smokey68321
18
Feb 5, 2010 01:21 AM
julianaa
20
Jul 2, 2007 11:44 AM
QUAIJAI
Jan 27, 2005 04:12 PM
Honda Sport
Jun 4, 2003 05:27 PM
